left front brake
Old Dec 29, 2008 | 08:10 AM
garndog's Avatar
garndog
left front brake
my left front brake is not releasing for some reason. any ideas?
Old Dec 29, 2008 | 08:15 AM
fxstbchopper's Avatar
fxstbchopper
Sounds like one of the pistons in the caliper is stuck.
Old Dec 29, 2008 | 08:17 AM
garndog's Avatar
garndog
what should i do for it? pull the rubber sleaves back and clean them out and lub them up?
Old Dec 29, 2008 | 08:24 AM
fxstbchopper
That is what I would do. Take it apart clean both pistons real good then lube them put the boots back on and test them before putting it back on the truck. You might be able to get by with just spaying the pistons down real good with WD40 and get it moving that way.
Old Dec 29, 2008 | 08:27 AM
garndog's Avatar
garndog
so take it off the truck or try it first with it on? its my only way around so i have to get it done fairly fast. thanks
Old Dec 29, 2008 | 08:33 AM
Whit350's Avatar
Whit350
Replacement of the caliper may be a better choice. If you perform the lube repair on the piston you run the risk of destroying another set of pads if it doesn't work. For me brakes on trucks this size are no place to try to "get by" cheaply. Good luck.
Old Dec 29, 2008 | 08:36 AM
fxstbchopper
I would say if you need it fast you could try it with it still on the truck but it would probably be easier on a work bench.
Old Dec 29, 2008 | 08:44 AM
garndog's Avatar
garndog
cool, thanks. i'll get to it than. let ya know my results later today.
