01 Ex High Idle
Old Dec 29, 2008 | 07:36 AM
usherac21's Avatar
usherac21
01 Ex High Idle
Hi, all...I have a 2001 Excursion 7.3, bone stock. I live in New England...It's been cold on and off lately. When I start it (even after block heater all night), it immediately starts and runs at an idle of about 7-800. It sounds like I think it should. After awhile, the idle kicks up to 1000+. It kicks down if I touch the accelerator, but then climbs back up. Is this normal? It even happens after the temp. gauge is in the "normal" range. I'm pretty new to these engines, so thanks in advance for the help.
Old Dec 29, 2008 | 07:52 AM
clux's Avatar
clux
Yes, it's normal, it's to help warm the engine up.
Old Dec 29, 2008 | 08:07 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Yes, like said this is normal. It should also sound like a Jet engine. That is the EBPV closing to put a load on the engine to help it warm up faster.
Old Dec 29, 2008 | 08:12 AM
white Buffalo's Avatar
white Buffalo
Just like Rick & Clux said - all normal. The engine does this to help warm itself up during cold conditions.
Old Dec 29, 2008 | 08:19 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Most definately, it's just the engine trying to warm up a little faster.
Diesel engines don't like the cold very much until they're warmed up. So in order to keep them warm and warm them up faster, the PCM slightly closes the exhaust backpressure valve on the turbo and high idles the engine. This effectively warms the engine up and gets the oil flowing much better than just idling at the normal RPMs.
Once it's warm, the ebpv opens as the engine is now up to temp and able to maintain it's proper operating temp easier. It's may close again to keep the engine warm if it's just that cold.
Old Dec 29, 2008 | 10:08 AM
usherac21's Avatar
usherac21
Thanks for all the replies. the guys (and girls) on this forum are the best.
Old Dec 29, 2008 | 10:17 AM
novice psd's Avatar
novice psd
Sounds normal, my f250 does the same, even after warmed up it will still do it if you idle 2-3 minutes.
