Winter Starting Woes
Old Dec 28, 2008 | 07:55 PM
Firefighter 1406's Avatar
Firefighter 1406
Well I drove my truck to work on Saturday morning, it started with no problems w/o being plugged in. It sat all day in 55 degree, rainy weather, I did not plug it in that Sat. night, and it dropped down to 25 over night. I come out Sunday morning to go home and the truck barely turns over. It has done this to me three or four times the past month, I put it on the charger and cranks right up, but not today. I put it on the charger, and it did crank better but would turn over but not fire, kind of had a chug chug sound to it and was blowing a lot of white smoke out of the tailpipe. I pushed it into a heated bay at work and let it sit for about two hours with the battery charger on and the block heater plugged in. When I came back to start same thing. I thought it might be a frozen fuel filter, so I went and bought a new one. When I took out the old one it was black. I replaced the filter less then 10,000 miles ago. I was wondering what caused all this problems. The batteries and starter tested good a couple months ago, but it seemed like the batteries where dead as a hammer when I first started to try to start it. I am pulling my hair out trying to figure it out. Any suggestions as to what could be contributing to the cause? Do I need to put a winter weight oil in it?, New glow plugs?, New gpr?, Batteries, Batt. cables?
I am sorry for the long post but I am going crazy with this truck.
Old Dec 28, 2008 | 07:58 PM
cadetcommander20's Avatar
cadetcommander20
i would say bad batteries i had the same problem and i had 1 bad battery so i replaced them both and problem solved
Old Dec 28, 2008 | 08:03 PM
swaybar's Avatar
swaybar
how bout your alternator?
Old Dec 28, 2008 | 08:10 PM
Firefighter 1406
I didn't test my altenator but it is newer. I could get it tested for the heck of it though.
Old Dec 28, 2008 | 08:13 PM
swaybar's Avatar
swaybar
what first made me think of this is my alternator needed replacement last week. it was only 18 months old and 15,000 miles.
my fault for buying a reman but something to look at.
Old Dec 28, 2008 | 08:18 PM
Firefighter 1406
thanks for the suggestion.
new2diesel's Avatar
new2diesel
I don't know for sure, but check your fuel bowl heater. You should not have black in your fuel filter. I think that the heater has insulators to keep it from shorting out on the bowl.
Those insulators deteriorate giving you the black. Also make sure you used Bosch GP's
I believe that is the same that Ford uses. Autolites are crap and will go south fast.
Old Dec 28, 2008 | 08:25 PM
Firefighter 1406
I have not changed the glow plugs yet, I have a brand new set of motorcrafts waiting to go in. I will have to check the bowl heater though. How hard are the glow plugs to change?
