6.0 Warm Start Help
Old Dec 28, 2008 | 07:01 PM
KS324's Avatar
KS324
6.0 Warm Start Help
06 6.0L wont start once oil gets above 175 degrees. Replaced the STC and still doing the same. Any suggestions???????
Old Dec 28, 2008 | 07:55 PM
zrt600guy's Avatar
zrt600guy
high pressure oil system leak somewhere...
Old Dec 28, 2008 | 10:42 PM
gofast117's Avatar
gofast117
More than likely your leak is at one of the oil rail plug orings.(the rail that supplies oil to the injectors.)
Old Dec 28, 2008 | 11:24 PM
KS324's Avatar
KS324
Is that the dummy plugs?? Can you get only the O rings to replace or do you need to get new plugs?
Old Dec 29, 2008 | 12:55 PM
gofast117's Avatar
gofast117
yeah its the dummy plugs. Ford part numbers for the orings are W301386 for the larger one and W301390 for the smaller. it is usually the smaller one that blows. I think it gets nicked when they install them at the factory.
Old Dec 30, 2008 | 09:02 PM
KS324's Avatar
KS324
Thanks that was it, the lower O-Ring, thankfully it was on the pas. side!!!
powerstrokeken6.0
Apr 19, 2014 07:18 PM
john6.0
Feb 9, 2014 05:36 PM
'94Nichols
Oct 10, 2011 08:55 AM
tangcoral2004
Sep 5, 2004 10:27 AM
Saxon
Jul 19, 2004 04:18 PM
