Engine squeal
Old Dec 28, 2008 | 02:52 PM
bcjim's Avatar
bcjim
Engine squeal
My 98 4.0 with 149K has developed a squeal. I thought it was a belt squeal, and it may be, but it doesnt seem like it from my cursory and brief (and unskilled) investigation. It is rpm dependent, it gets faster sounding when I hit the gas. Seems to have a bit of a cadence to it, its not a constant monotone squeal if you know what I mean. Disappears from time-to-time as well, but comes back. No codes. Seems to run ok, though I have not used it much since the noise showed up. No power loss or anything like that.
Any ideas?
Old Dec 28, 2008 | 04:18 PM
matt's2.9STX's Avatar
matt's2.9STX
Could be any of the accessories the serp belt runs around from your description, although I'd guess the idler off-hand from all that. Where does it seem loudest? Again, like so many other topics, you could probably use a mechanic's stethoscope, a small rubber hose around 3/8" ID or a 12" or so tube to use against your ear to focus on each part. With a tube, I'd go longer or better yet, use a brake or fuel line attached to a rubber hose.
Old Dec 28, 2008 | 04:22 PM
g_k50's Avatar
g_k50
Have you changed your belt recently?
My understanding is that non Ford belts sometimes squeal due to an inexact V shape.
Old Dec 28, 2008 | 05:28 PM
pgw85706's Avatar
pgw85706
Idler pulley would be my first guess.
Old Dec 28, 2008 | 07:38 PM
drb1956's Avatar
drb1956
Thumbs up
I put a Goodyear Gatorback(serpentine), and its been nothin' but quiet, in all kinds of weather...I vote its a pulley on an accessory(power steering,air cond., etc..) and/or idler pulley, or the belt tensioner...You could TRY to squirt WD, or something like it while the truck is idling, just keep your hands out the fan, and keep your face out of the line of return fire when you spray. Try one thing at a time until it stops....
Old Dec 29, 2008 | 07:52 AM
bcjim's Avatar
bcjim
OK Thanks for the suggestions. The belt is not new but not ancient. I'll investigate further...
Old Dec 29, 2008 | 04:05 PM
bcjim's Avatar
bcjim
OK, it may be the belt and/or idler pulley. Belt is simple enough to deal with. WHat if the pulley is the problem? What is the solution?
Old Dec 29, 2008 | 05:00 PM
matt's2.9STX
Get a new one. As long as you have sufficient belt tension, that's all you should have to replace.
