f-250 Rear Diff Help
Old Dec 28, 2008 | 02:27 PM
stowe44's Avatar
stowe44
i Have an 1982 f-250 4x4. i was trying to figure out the front and rear gear ratios but could not find these anywhere. On the door jam the axle code reads
C72 6G8
But i took the badge off the rear diff and it read
3 54 E2TA TB
605086-6 LS
Could someone please decode this for me.. Thanks alot
Old Dec 28, 2008 | 03:16 PM
uncle.stosh's Avatar
uncle.stosh
3.54 to 1 The most common ratio.
3 54 E2TA TB
Easy enough, eh?
Old Dec 28, 2008 | 03:18 PM
82F100SWB's Avatar
82F100SWB
You have a semi float Dana 60 in the rear, with 3.54 gears and a limited slip, and from that axle code(C72) you have a limited slip front also, probably a 44HD judging by the light rear axle in that truck.
Old Dec 28, 2008 | 06:21 PM
stowe44's Avatar
stowe44
wow thats awsome. really impressed not thanks a bunch guys
Old Dec 28, 2008 | 06:52 PM
uncle.stosh
If you have a LS front and rear you are pretty lucky. I wish mine had a LS in both axles.
Old Dec 28, 2008 | 08:24 PM
Franklin2's Avatar
Franklin2
He lives in Canada, so I assume he will get to drive it in the snow. I would like for him to write back in with his experiences with it since it has the limited slip in the front.
Old Jan 7, 2009 | 03:46 PM
stowe44's Avatar
stowe44
hay sorry guys i've been busy trying to get it running.. it is kind of just a donor truck.. bought it for the engine but after hearing its front and rear LS trying to get it running.. just rebuilt the starter yesterday... its been too damn cold here to put it back on! as soon as its running ill fill you guys in how it is!
Old Jan 8, 2009 | 09:37 AM
bashby's Avatar
bashby
wouldnt the tag read 3L54 if it was a limited slip?
eduhat
Dec 22, 2015 06:29 PM
Herbward1
Apr 4, 2015 05:24 PM
Gear619
15
Apr 3, 2015 02:26 PM
happscrap
Nov 24, 2014 09:55 AM
Patchy 73
Australia Chapter
Sep 7, 2014 11:48 PM
