Power Window Prob
Old Dec 28, 2008 | 12:50 PM
BamaDave's Avatar
BamaDave
Exclamation Power Window Prob
Can anyone help me with how to remove and install drivers side window motor. I rolled the window down the other night and it wouldn't go back up. I can hear the motor running in both directions. I took the door panel off and looked at the cables and track system and it all looks fine. This is leading me to believe it is the motor. I did a search and couldn't find where anyone had detailed directions to remove the motor. It looks like you have to remove the whole cable pulley and track assembly to get the motor out, PLEASE TELL ME YOU DON"T HAVE TO DO THIS. Any help would be appreciated.
Old Dec 28, 2008 | 02:23 PM
BamaDave's Avatar
BamaDave
help pleez....
Old Dec 28, 2008 | 03:58 PM
BamaDave's Avatar
BamaDave
bump....bump
Old Dec 29, 2008 | 06:38 AM
ccecilm2's Avatar
ccecilm2
The last post in this link ( https://www.ford-trucks.com/forums/6...-problems.html ) has some instructions. Search for "regulator" (without the quotes) and a lot of threads will come up. Good luck.
Old Dec 30, 2008 | 03:53 AM
thomasf150's Avatar
thomasf150
bamadave, I had the same problem with my window in my 2006 F-150, I almost went to the trouble to replace the motor, come to find out it was nothing but my driver side window switch. It might not be the case in your situation but its worth checking into before you spend the bucks on the window motor.
Old Dec 30, 2008 | 06:28 AM
ChargersFanInCO's Avatar
ChargersFanInCO
bump...I'll trade you problems...
bigacre
Aug 26, 2009 01:35 PM
73 Bronco Exp
Oct 15, 2004 05:57 PM
