Sponsored by: Real Truck
Using leveling kit for lifted SD
Old Dec 28, 2008 | 12:29 PM
Kuuner's Avatar
Kuuner
I have what appears to be a 4", "Full Traction" lift on my 05' SD Crew Cab. I just put 37"'s on her and well, you know the rest. I get rub on inner fender well. I already cut the front bumper a tad and don't want to ghetto it out anymore than I already did. I do NOT want to cut the inner well. Can I use a leveling cat AFTER a lift has already been installed? I only need another half inch (Funny...the wife says that to me too)!
Old Dec 28, 2008 | 01:03 PM
high ho silver's Avatar
high ho silver
Don't cut the inner liners. Just pull them back until you get no more rub. I did mine using a piece of stainless steel tubing on each side. Cut them the length I needed and made flat spots on the ends with a vise. Then drilled holes in the flat spots for bolts. Bolted one end to the area of the liner where it rubs the most and pulled back quite a bit and scresed the other end to the bottom of the cab frame.
EF2FITTY
Mar 11, 2015 03:19 PM
NavyMIDN08
Aug 18, 2011 05:19 PM
JonR
Feb 1, 2008 07:16 PM
goldman
17
Feb 5, 2006 09:58 PM
RE_SPEED_FAB
Feb 27, 2002 11:27 AM
