Hard Starting Cold
Old Dec 28, 2008 | 09:36 AM
Aebiguy's Avatar
Aebiguy
Unhappy Hard Starting Cold
My 2000 F-350 (368000m) has developed a cold blooded attitude this fall. It just won't start without being plugged in below about 20 degrees F. I cycle the glow plugs and all it does is crank, lots of black smoke and once in awhile I'll get lucky and it will start with lots of cranking. If I plug in the block heater (4-6 hours ) it takes right off. Also - when started cold it sometimes misses, but usually not when plugged in. Replaced the air preheat solenoid - seemed to help but not to cure. Anyone have any suggestions? I'm thinking maybe tired glow plugs.....
Old Dec 28, 2008 | 10:19 AM
tjc transport's Avatar
tjc transport
i ain't rite
it may be glow plugs, or it may be the glow plug relay.
you will have better luck posting here https://www.ford-trucks.com/forums/forum31/
this is the forum for your 2000 power stroke. they will be able to better answer your questions there.
hydroman916
Jul 5, 2010 10:25 AM
klmracing
Dec 15, 2009 07:13 PM
firebug
Jan 20, 2007 09:07 PM
ALL BOY
Jan 9, 2006 06:07 PM
quiethorse
Dec 7, 2004 11:00 PM
