460 Identification
Old Dec 27, 2008 | 09:25 PM
f150lightning825's Avatar
f150lightning825
460 Identification
I am going to look at a 78 f150 for sale. The seller says it has the 460 in it. Is there an obvious way to tell wether its a 460 vs like a 351M or 400?
Thanks
Old Dec 27, 2008 | 09:51 PM
f150lightning825
Nevermind, I found the vin id on this forum
https://www.ford-trucks.com/forums/3...-research.html
Old Dec 27, 2008 | 10:08 PM
f150lightning825
nevermind, found what i was looking for
Old Dec 27, 2008 | 10:09 PM
rwlacks's Avatar
rwlacks
Two easy ways the oil dipstick will be in the alum. timing cover also the water neck is mounted on the intake
Old Dec 27, 2008 | 11:04 PM
Scolesy8's Avatar
Scolesy8
valve cover bolts... the 351 and 400 has 8 and the 460 has 6 i believe, but dont take my word for it
Old Dec 28, 2008 | 07:00 AM
rwlacks's Avatar
rwlacks
The 460 has 7 bolts in cover just built mine last week
Old Dec 28, 2008 | 08:38 AM
monsterbaby's Avatar
monsterbaby
If it has a rear sump pan the dip stick will be in the pan NOT in the timing cover. Now if it is a stock 2wd then it should have it in the timing cover due to those using a front sump setup BUT if it's a swap into a 4x4...
Old Dec 28, 2008 | 09:10 AM
rwlacks's Avatar
rwlacks
True mine is 2wd with front sump I need more coffee !!!
Look at my post Project 0078 . give me time and lots of cash one day i will finnish this truck
bigtrkpup
Aug 20, 2012 08:52 PM
david00f150
Jul 28, 2010 11:32 PM
1987blueovalcrazy
Aug 28, 2003 08:05 PM
Brian460
Nov 5, 2002 04:48 PM
jer
Dec 13, 2000 05:20 PM
