What size tire to run.
Old 12-27-2008, 02:02 PM
TownsWi's Avatar
TownsWi
TownsWi is offline
I got a 2.5 inch leveling kit for Christmas and I would like to know what would be the best size tire to run.
Old 12-27-2008, 03:50 PM
WhëëlMå1's Avatar
WhëëlMå1
WhëëlMå1 is offline
Welcome to FTE. How about letting us know what truck you have?
Old 12-27-2008, 05:09 PM
SUPERDUTY_untouchabl's Avatar
SUPERDUTY_untouchabl is offline
2wd 33" is the max. I belive 35" is the max on 4wd. It basicaly comes down to what size you think looks the best...
Old 12-28-2008, 02:11 PM
TownsWi's Avatar
TownsWi
TownsWi is offline
I got a 2008 f150 FX4 4x4 i want to run a 35. Does a 325/65-18 come out to be a 35 or what other tires are out their that come out to be around a 35?
Old 12-28-2008, 02:15 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
that is the size
recommend you only run a 305 width tire though unless you are running aftermarket rims
the 325 will fit on OEM rims, but it will be mighty close to the upper control arm
Old 12-28-2008, 02:24 PM
TownsWi's Avatar
TownsWi
TownsWi is offline
so what size would be the best recommendation im going to be running stock rims
Old 12-28-2008, 03:12 PM
triple8's Avatar
triple8
triple8 is offline
Originally Posted by tylus
that is the size
agreed. i just did the 305/65 18 BFG AT's. they fit great and are about 34" high. anything wider would be way to close to the control arm for my comfort. if you have 17's go for BFG's 315. it is closer to 35" high but slightly narrower at 12" instead of 12.2"(according to BFG site)
this is a 2"autospring kit with 305/65 18's
Old 12-28-2008, 04:07 PM
silver05fx4's Avatar
silver05fx4
silver05fx4 is offline
I'm running 305-70-18 mickey tompsons atz which is all most a 35 and fits good
Old 12-28-2008, 04:53 PM
fordman19762003's Avatar
fordman19762003
fordman19762003 is offline
triple8, those tires look good on your truck, did you have to do any trimming to keep the tires from rubbing at full lock? Also, how much clearance do you have between the tire and the control arms, and do the tires stick out past the fenders?
Old 12-28-2008, 08:13 PM
Catmonkey's Avatar
Catmonkey
Catmonkey is offline
I'd pick my tire size based on my present gear ratio. 35's may look good, but unless you change your gear ratio to compensate, you will have poor performance and gas mileage will suffer. Check the tire manufacturer's specs for fitment on stock rims. The widest tire I have seen for 7.5" wide rims is a 285 mm cross section.
Old 12-29-2008, 07:49 AM
triple8's Avatar
triple8
triple8 is offline
i did not trim anything. with the wheels turned to be as close as possible to the fenders there is still about 1.5" of clearance to the plastic fender lip at the back and about the same to the plastic air dam under the bumper in the front. this is on flat ground. i have noticed no rubbing at full lock. as for the upper ball joint there is only about 1/2" of clearance,turned to the control arms i have not looked at.
they do not stick out either. here is a shot of the front of the truck
