2007 King Ranch Remote Programming
Old Dec 27, 2008 | 11:53 AM
ronmessa's Avatar
ronmessa
I can not get my truck into programming mode using these instructions:
To program the transmitters yourself:
Insert a key in the ignition and turn from 3(Off) to 4(On) eight times in rapid succession (within 10 seconds) with the eighth turn ending in the 4(On) position.
The doors will lock/unlock to confirm that programming mode has been entered.
Any suggestions?
Old Dec 27, 2008 | 12:18 PM
stanger_missle's Avatar
stanger_missle
I just bought a new key fob off of Ebay beacuse my '06 XLT did not have one.
Basically, I had to insert the ignition key and turn it from lock to the on position 8 times, ending in the on position within 10 seconds.
As soon as you get to the 8th time, the door locks will lock then unlock. Then press any button on the remote. The door locks will then lock then unlock.
Turn the ignition off and remove the key. I waited about 10 seconds to try the remote. Worked like a charm. I had to do the key cycling a few times because I kept stopping at 7 (doh!). Just remove the key and wait for a bit before trying again.
Good luck!
Old Dec 27, 2008 | 12:45 PM
ronmessa's Avatar
ronmessa
Thanks I got it to work. I fastened the seat belt so it wouldn't ring when I left the key in the on position. Don't know if it made a difference are not.
Stewart_H
Jan 6, 2024 10:21 PM
Number21
Dec 20, 2013 11:22 AM
Apocalypse
Dec 17, 2012 04:27 PM
TwoMuchMud
Escape & Escape Hybrid
Oct 11, 2011 11:00 PM
86F150302
Mar 13, 2009 12:37 AM
