Adding a second fuel filter head.
Old Dec 27, 2008 | 05:16 PM
EMD_DRIVER's Avatar
EMD_DRIVER
I got it mounted today, but haven't plumbed it yet. I put a 6.9 filter ahead of my stock 7.3 filter. My original intent was to allow the 6.9 filter to clean the fuel enough that the 7.3 filter wouldn't have much to do, other than act as a water separator. Right now, I have a NAPA 3403 filter on it. The 3403 is twice the length of the standard 6.9 filter. I was surprised to find that there was plenty of room for it. For right now, my heater hose is routed between the two filters. The only problem I ran into, is the A/C line. It is a bit snug, but it runs over the new filter head. I cut a piece of old air hose, to protect it from rubbing through. I will have pictures tomorrow.
Old Dec 27, 2008 | 10:38 PM
IHdieselfan's Avatar
IHdieselfan
buy a 86417 filter instead of the 86217 there cheaper for the 7.3 base
Old Dec 27, 2008 | 10:48 PM
EMD_DRIVER's Avatar
EMD_DRIVER
I bought one from NAPA and it was $10 more than the OEM-type. Go figure!
Old Jan 2, 2009 | 04:54 PM
IHdieselfan
there are three different filters from wix to fit the 7.3 base
33217 is oem this one you have to use the original metal base $28.99
33417 is a replacement with just a drain on the bottom $21.97
33617 is a replacement with a place for the h2o sen. and a drain $23.99
These prices are with my company acount
Old Jan 2, 2009 | 06:43 PM
EMD_DRIVER's Avatar
EMD_DRIVER
Best price I could get on the 33617 was $36.. That was with the railroad's account.
Old Jan 3, 2009 | 01:05 AM
S.P.'s Avatar
S.P.
Which NAPA filter for the 7.3 filters the finest...
On the second thur./fri. they have 50% off their NAPA filters...
Old Jan 3, 2009 | 01:37 AM
LCAM-01XA's Avatar
LCAM-01XA
Think they're all the same, 12-micron for the 7.3 filters, 6-micron for the 6.9 hence why I suggested stacking them.
Old Jan 6, 2009 | 09:02 PM
IHdieselfan
there all 12 micron filters
6 months ago i could get the 33417 for $19 but they went up a little
Old Jan 19, 2009 | 06:13 PM
EMD_DRIVER's Avatar
EMD_DRIVER
Here are the pictures I promised, of my second fuel filter. It's the 6.9 head and a NAPA 3403 filter. I like this filter, because it is almost twice as long as the stock size filter.
The heater hose will be rerouted, when I do my coolant filter mod. I used 3/8" air hose, to make a chaffing block for the A/C line. In retrospect, I should have just made the filter and mount a bit lower.
Old Jan 19, 2009 | 06:15 PM
EMD_DRIVER's Avatar
EMD_DRIVER
The clamps on the battery terminal, are because I drained the batteries trying to start it. I was getting ready to take it for a test drive, after the carrier bearing/U-joint repair.
Old Jan 20, 2009 | 08:52 PM
IHdieselfan
yea thats exactly how i mounted my coolant filter. are you getting your coolant filter set up for wix/napa
Old Jan 21, 2009 | 05:18 AM
EMD_DRIVER's Avatar
EMD_DRIVER
Yep, I'll also be using the pre-charged filters. I haven't yet figured out exactly where I'm going to mount it though.
Old Jan 21, 2009 | 07:15 PM
  #28
IHdieselfan
yea i've put coolant filters on all of my equipment even on my wifes explorer. on all of my diesels i use the precharged filters(89071,89072,89073), on the gas burners I use just the blank filter.(89070) i love them. i put little 1/4 turn valves on them for filter changes. (I think wix should send them in the kit)
if your truck doesn't have cruise you can use that mounting tab on the drivers side fender.
i use carquest filters if you can't tell already.
that 86403 is a 10 micron filter you can also use 86338 in place of it and its a 6 micron filter
the way it looks you have your fuel setup the first filter stops everything and all the stock one does is a water seperator.
that a international truck 6.9 filter base ain't it
Old Jan 21, 2009 | 08:03 PM
  #29
EMD_DRIVER's Avatar
EMD_DRIVER
That pretty much sums it up! The 6.9 filter is a 6 micron, while the 7.3 filter is like 10.
Old Jan 23, 2009 | 05:53 AM
  #30
IHdieselfan
no that 86403 is a 10 micron use a 86338 its a 6 micron
genscripter
May 26, 2017 08:45 PM
genscripter
85
May 9, 2017 10:02 AM
artfd
Jan 1, 2012 08:13 PM
morimoto_87
19
Aug 11, 2010 09:46 PM
topgunn
22
Oct 29, 2009 05:55 PM
