Sponsored by: Real Truck
Cab Light install problem
Old Dec 26, 2008 | 10:01 PM
aphotic26's Avatar
aphotic26
Hey FTE, hope everyone had a merry christmas.
I got a pair of cab lights for christmas and I followed the instructions carefully.
The kit includes a switch, inline fuse, lights and wiring.
I have my inline fuse connected to my battery to my on/off switch, the switch has a proper ground and then my wiring goes from the switch to the lights...easy enough. My switch glows red and all the wiring reads 12v and my connections are secure...but the cab lights just wont turn on.
I've check the bulbs they are fine I don't know what's wrong...any help will be much appreciated thanks.
-Matt
Old Dec 26, 2008 | 10:05 PM
73f100shortbed's Avatar
73f100shortbed
Do you have a good ground to the lights?
Old Dec 26, 2008 | 10:08 PM
aphotic26's Avatar
aphotic26
Yeah I do its under my dash and its connected to an existing ground
Old Dec 27, 2008 | 12:02 AM
bayou barataria's Avatar
bayou barataria
Not all of the metal under the dash is grounded, that sounds like a ground problem. Did you check the voltage at the lights themselves?
Old Dec 27, 2008 | 09:36 AM
bpounds's Avatar
bpounds
If they are LED lights, you might have the polarity reversed.
Old Dec 27, 2008 | 09:57 AM
redford's Avatar
redford
FTE Leadership Emeritus
Is your "under dash" ground for the switch or for the lights?
Usually, the ground wire under the dash is JUST for the indicator light on the switch. The lights themselves need a separate ground to work. That is usually supplied through the mount to the body, but paint, insulation or sealant may be preventing the light to get a good ground to the body.
JamesF-250
13
Aug 18, 2014 05:19 AM
rews2
Aug 4, 2014 12:43 PM
jake5611
Jan 19, 2009 03:08 PM
tomtoc
Aug 25, 2007 12:45 PM
weldman
May 25, 2002 09:22 AM
