drive line picks
Old Dec 26, 2008 | 06:20 PM
joe f350's Avatar
joe f350
drive line picks
it looks like the preives owen beat me to droping the carrire bearing i put picks of the lift up to
Old Dec 26, 2008 | 06:32 PM
George D.'s Avatar
George D.
It looks like that block may be a bit too big. If the drive shaft is inline with the yoke you wont have enough of a working angle in the ujoint wich could be causing your problem.
Old Dec 26, 2008 | 06:35 PM
joe f350's Avatar
joe f350
how much angle should i have o some on with a chizle cut half way there the ujoint strap bolts my quess is they dont like my truck
Old Dec 26, 2008 | 06:44 PM
George D.'s Avatar
George D.
If the bolts were loose it would look like some one was trying to cut threw them from the staps moving around on them.
From what I just found it sould be atleast 0.5 degrees minimum and no more than 3.5 degrees maximum
Old Dec 26, 2008 | 06:45 PM
George D.'s Avatar
George D.
Heres a link to where i found that http://www.classicchevy5speed.com/fi...roc_111606.pdf
Old Dec 26, 2008 | 06:46 PM
joe f350's Avatar
joe f350
thx the nutts whert loose my dad looked at then and my brothers and uncle they all ay there tool marks
Old Dec 26, 2008 | 06:57 PM
starmilt's Avatar
starmilt
How much did they lower the bearing.
Have you made sure your driveline was timed right 1 tooth off makes a lot of differance some slip yokes has a double tooth so you cant get it out of time.
This is what I would make sure your driveshaft is straight install ujoint take your time and make sure the locks are in correctly.
Make sure your carrier bearing is in good shape and your driveline is timed right.
Make sure your slipyoke slides freely. Tighten everything up.
Now check your slipyoke for slop side to side to up and down same with carrier bearing.
Test drive it if your satified everything above is correct and still have a vibration try moving your carrier bearing back to stock location (make sure you still have enough splines in the slipyoke check again for slack) drive again.
Also make sure your vibration is driveline related your big tires sometimes cause vibrations feels differant but I cant describe it.
Old Dec 26, 2008 | 07:04 PM
joe f350's Avatar
joe f350
when i find the person who cut my bolts iam video tape it
Old Dec 26, 2008 | 07:10 PM
George D.'s Avatar
George D.
Do you have any pictures of the bolts in your gallery?
Old Dec 26, 2008 | 07:18 PM
joe f350's Avatar
joe f350
last one i will get a better shot
Old Dec 26, 2008 | 08:11 PM
starmilt's Avatar
starmilt
Think about this if somebody went to the trouble loosen the bolts cut them with a chisel and tighten them back up you have really pissed off somebody. Are you completly sure your caps fit that new yoke correctly.
Old Dec 26, 2008 | 09:07 PM
jo7.3idi's Avatar
jo7.3idi
if your drive shaft was floping around thats what made those marks i had a u joint break and it beat the crap out of my fuel tank and banged up my bolts that hold the u joint to the rearend and bent the peaces that hold the u joint to the rearend all to hell.
Old Dec 26, 2008 | 09:54 PM
Dave Sponaugle's Avatar
Dave Sponaugle
From looking at the angle out of the transfer case and the angle at the axle pinion I also agree the carrier bearing has been lowered to far.
How far is it from the bottom spring in the spring pack to the top of the spring perch?
That looks like a standard 4" F350 block to me.
Old Dec 26, 2008 | 10:23 PM
joe f350's Avatar
joe f350
the chizle mark was under the blot head like he losened the bolt hit it and them srewed it back in i was drive right after strait piped it and some young lady yell at me to slow down i was only going 25 but it sounded a lot faster he live around the block maybe she has a boy freind i dont know the marks where under the blot head
Old Dec 26, 2008 | 10:28 PM
starmilt's Avatar
starmilt
That is why I dont think your caps were the right ones for the yoke I'm thinking 1/16 off.
