Strange grinding noise
Old Mar 17, 2009 | 09:55 PM
mtsz52784's Avatar
mtsz52784
My '03 Expy has been making the same rubbing/grinding noise for the last couple weeks... not every time but def on a cold startup and only on right turns... taking it in next week to the dealer to get them to look at it, will update when I find out more.
Old Mar 18, 2009 | 06:55 AM
ExpySport's Avatar
ExpySport
Originally Posted by nutherford
I know this problem was several months ago, but I'm curious about something. Did you happen to notice a squeak in the front wheel a while before you heard the grinding? I've got an '03 Navigator with 74k miles. I've got a squeak a low speeds, especially when I brake to a stop and then start forward again. Mechanic recommended replacing the front hub bearing and the bearing assembly. I'm wondering how long I have until I get to where you were.
2003 Lincoln Navigator, 5.4L DOHC V8
74,000
I didn't really notice a squeak prior to the grinding. The grinding progressively got worse and worse. I replied to another post about this (perhaps it was yours?) about the cost of doing the job. They were quoted $850 - mine only cost $560, parts and labor.
Old Mar 18, 2009 | 08:29 PM
nutherford's Avatar
nutherford
Yep. That was me. I was looking around for anything having to do with the hub assembly. Sorry for the duplication. I appreciate the response - both times!
Old Mar 19, 2009 | 11:57 AM
ExpySport's Avatar
ExpySport
No problem. That's what we're all here for - to help everyone with their questions!
Old Mar 23, 2009 | 03:12 PM
apgarassoc's Avatar
apgarassoc
Replacing Your Front Hubs
See my write-up on how to do it.
https://www.ford-trucks.com/forums/8...nd-rotors.html
Old Mar 26, 2009 | 02:59 PM
mtsz52784's Avatar
mtsz52784
Went to the dealership today! Ended up that the Left Wheel hub bearing was bad... since I have the Certified Pre-Owened Extended warranty they just happen to have 2 in stock and replaced the Right one as well... awww how nice.... costing me only $100.00 to get both hubs replaced!
Old Mar 26, 2009 | 07:33 PM
ExpySport's Avatar
ExpySport
Wow, you made out on that deal!
Old Jun 5, 2009 | 09:25 AM
pf2130's Avatar
pf2130
Exactly what do I put in the differential of my 2003 2WD Expy
Forgive me if this is elementary but what fluid do I need to put into the differential? Can I get the friction modifier at a NAPA dealer?
I am having the issue described in the post - grinding noise, louder when turning.
bulldog97
2004 - 2008 F150
Apr 11, 2016 07:46 PM
durtbikefool
Jan 20, 2016 09:30 PM
t-loc1
1997 - 2003 F150
Dec 10, 2015 09:20 PM
t-loc1
Dec 10, 2015 09:17 AM
georgiafordowner
Jun 25, 2014 08:44 AM
