Not you everyday 4WD issues - HELP!!
Old Dec 26, 2008 | 03:33 PM
Blacknav's Avatar
Blacknav
Hi All,
I have a 98 Navi and cannot get the 4WD to engage. I've been battling this beast for a while and am running out of ideas. I've changed multiple things and just yesterday put on a new T-Case thinking that may be the problem (it wasn't)
When I move the switch on the dash the light on the instrument panel will show the correct selection (A4WD, 4x4 or 4LOW). If I put the truck in neutral with the brake pressed I can go into 4WD Low and I hear the thud as the Transfer case engages but the front wheels still do not turn. I even get clicking from both the 2wd and 4wd solenoid on the pass. side firewall when I move the switch with leads me to think that they are working.
If i put the truck into 4x4 the light stays on without flashing or anything but I cannot get the front diff to lock.
Any suggestions on what I'm missing?
Also Does anyone know which vacuum line needs to be pulled from the solenoid to engage 4wd I can't think of how else to check them (In case it is the solenoid)
Old Dec 26, 2008 | 04:45 PM
heymrdj's Avatar
heymrdj
Have You checked the front differential/axle/hubs? Sounds like obviously somethings not locking on the front end that should be. Is the differential from the tcase to the front hub even spinning? If it is then your issue is in your axle. I would have to say if there's no signs of binding issues it's most definitely the hubs not locking, which is probably vacuum related.
Old Dec 26, 2008 | 05:12 PM
alloro's Avatar
alloro
Is the front driveshaft turning? If it isn't you still got a problem with the TC, if it is then you've got an axle to wheel locking problem.
The easiest way to know if the front axle is being powered is to wrap a large tie-wrap around it and take a short drive. If you hear the slap, slap, slap of the tie-wrap then the driveshaft is powered.
Old Dec 26, 2008 | 06:31 PM
atvfan's Avatar
atvfan
You have a problem with the front axle engagement. Check vacuum lines and solenoids behind battery on firewall, and actuator on top right of front axle.
Old Dec 29, 2008 | 09:02 AM
Blacknav's Avatar
Blacknav
Thanks Guys, the front Driveshaft is turning so looks like the transfer case is OK. When going from 2wd to 4x4 I can feel the 4wd solenoid on the firewall click but I dont know how to check it further than that. I read on here a while ago that you can either pull a vacuum lines from one of the solenoids OR swap two lines around to see if the issue is the issue is the solenoid or the switch on the diff.
Old Dec 29, 2008 | 05:48 PM
4speedoverdrive's Avatar
4speedoverdrive
I had a similiar problem on a 97 Expy. Turned out the vacuum lines had hit the exhaust manifold and were melted shut. Usually you would look for a vacuum leak but the vacuum lines were sealed shut so they did not leak when tested.
Old Jan 6, 2009 | 03:34 PM
Blacknav's Avatar
Blacknav
Ok so after much headache I think I have narrowed down the issue. I pulled of the vacuum lines on the little switch on the front diff and applied vacuum with a manual pump. The lever on the dif moved in and out locking the diff correctly. So I moved on and checked to line on the solenoid using a vacuum gauge and it turned out the 2wd solenoid is leaking causing constant vacuum to be aplied to the line on the 2WD side. So even though my 4WD solenoid kicks on to pull the lever on the front diff, the leaky 2wd solenoid is preventing it from moving all the way over. Just picked up the solenoid today from Ford. (fingers crossed)
underdogl3
Feb 18, 2016 07:00 PM
BGreener
1997 - 2003 F150
Jan 14, 2013 10:03 PM
GMCfourX4
1997 - 2003 F150
Apr 9, 2007 10:06 PM
Munkey
Feb 13, 2006 12:39 PM
