Hi everyone, My truck (02 F350) has developed a chatter or knock while riding over bumpy road surfaces. I can't pinpoint where it is coming from. I noticed my steering stabilizer was a little loose and leaking so I changed it. still no fix. The steering seems fine/ no abnormal tire wear, all the brakes have been done recently, and the suspension seems to look fine. Am I looking in the wrong spot maybe a ball joint or shocks or bushings. What should I be looking for? Thanks in advance.
Hate to be the bearer of bad news, but probably the ball joints. That series of f250 and f350 are bad about it. Jack up the truck by the frame, not by the suspension, until the front wheels are about 3 inches off of the ground. Stick a prybar or something close under the tire from the side and pry up a little. if the tire moves and the control arm doesnt, it is the ball joint. Even a good one will move a little, but if there is excessive movement that is the problem.
Mine is doing the same thing. I think I've ruled out the ball joints, seem tight. I replaced the shocks, didn't fix it. Now I'm looking to order new sway bar end links. Mine look to be a little cracked and deformed, hope this is it. At the same time I hope I can find a good set of urethane bushings for the sway bar as well.
My sway bar bushing have a little play (gonna replace them anyway) but I'm thinking most of my noise is from the end links and I think their only available through Ford.
another option to rule out a sway bar bushing is to quickly remove one end (both sides of course) strap em safely...and do a short drive over bumpy roads..
if the noise dissapears then u know it is the sway bar.. if the noise remains then u got another problem..
it might seem like a slight hassle but its cheaper then just throwing money at it and see what fixs it..
