Urgent Need Help!!!!!
Old Dec 25, 2008 | 11:25 AM
smallz5.4's Avatar
smallz5.4
Well i took the mule out mud riding last night..... the inspection plate over the flywheel was punctured and leaking oil. im visiting family in alabama and i live in houston, i just need to know why would their be any oil between the flywheel and engine? And does anybody have any quick fixxes for this?
Thanks,
Devin
Old Dec 25, 2008 | 11:33 AM
F350-6's Avatar
F350-6
Welcome to FTE. The common spot for an oil leak is up on top of the motor. It runs down the back of the engine and could end up in the inspection plate. Check the top of the motor between the heads and see if you have any oil pooling up there.
Also, if you knocked things around hard enough, you might need to check the rear main seal or input seal on the tranny for any leaks.
Old Dec 25, 2008 | 11:39 AM
SpringerPop's Avatar
SpringerPop
smallz5.4,
Since you don't say, and you don't indicate in your profile, what truck are you driving with a 7.3L diesel in it?
That info will help us to figure out where to start looking.
Pop
Old Dec 25, 2008 | 01:30 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Thanks,
Devin
If you can patch it up to make the drive back, I'm out in Spring I'll see if we can't get that fixed for you.
What engine you got?
Old Dec 26, 2008 | 11:17 AM
novice psd's Avatar
novice psd
This thead looks like it should be moved to the F150 forum.
