Well I'm ready to put a dp in my rig. It's a one piece so I know I will need to cut it and put a band clamp in place. Question is can yall tell me the general procedure of removing the old one and puttin the new in? Any info is appreciated. Thanks and Merry Christmas
Drop the rear of the tranny helps a bunch! Why are you sayin gyou need to cut it??? Don't Cut It! go in from the top with the new one!
I cut my old DP in three pieces with a plasma cutter and it came right out! The new one will slip down from the top real easy. The instructions might say go from the bottom.
Have fun an Merry Christmas !
the one on my dp is different style then the stock one, it should work fine removing the tranny crossmember and letting it drop all the way down makes a big difference on the install. that was the trick to the dp's on the new body style trucks.
When you get the old one out and you make room (bend the crap out of your firewall seam) jack up the front it should slide in from the bottom,I can take mine out in one piece and put it back in from the bottom in one piece just need to make the room for it.
Merry Xmas
the Best gift this Xmas was the smile on my daughters face when she came downstairs this morning
