Nitrogen filled tires?
Old Dec 24, 2008 | 11:33 AM
Carnivore's Avatar
Carnivore
What does filling your tires with nitrogen do? Some dealers charge extra for that?
Old Dec 24, 2008 | 11:55 AM
Coupleofords's Avatar
Coupleofords
'Regular' air contains some moisture (water) which expands and shrinks with temperature. Nitrogen has almost no moisture, so your tire pressures remain much more consistent, resulting in better handling, wear, and mileage.
Old Dec 24, 2008 | 12:47 PM
xjcamaro89's Avatar
xjcamaro89
Ive also read on other forums (chevy) people were wondering about filling their tires with helium for better gas mileage. i dont think anyone actually did it cause of the cost and actually finding someone to do it, but i have seen it duscussed, and i dont think it would give you better mileage anyway
Old Dec 24, 2008 | 12:52 PM
Buck 1's Avatar
Buck 1
Filling the tires with nitrogen will result in better wear and constant correct pressure. While no one will state that your MPG will improve, it is only logical that if your tires are always properly inflated your MPG will improve. I have had nitrogen in my '08 F-150 since it was new, and definately notice an improved ride.
Old Dec 24, 2008 | 01:15 PM
sammer4u's Avatar
sammer4u
What is the cost of filling the tires with Nitrogen if I may ask?
Old Dec 24, 2008 | 02:03 PM
wildcard30's Avatar
wildcard30
Try these threads. Lots of good info...
https://www.ford-trucks.com/forums/6...-in-tires.html
https://www.ford-trucks.com/forums/6...pressures.html
Old Dec 24, 2008 | 02:18 PM
wildcard30's Avatar
wildcard30
I bet I could replace your nitrogen with normal air and you would never notice the difference... Normal air is 78% nitrogen and 21% O2 and 1% other gases... So how can a 22 % difference in composition make for a difference in the way a truck rides?
So... You have had nitrogen in the tires since new and never had air in 'em. Just how do you notice a difference in the way your truck rides if the tires have never been filled with air?
Nitrogen fills are just a way to separate you from your money......
Old Dec 24, 2008 | 03:17 PM
shorebird's Avatar
shorebird
Your tires are not the only things that are full of it.
Old Dec 24, 2008 | 03:21 PM
Bobby82490's Avatar
Bobby82490
X2^^
The nitro fill dealers sell is a rip off... with as many nitro fills I have done at work, I havent noticed a difference in any vehicles. Most vehicles that get it done it costs around $50-$70.
Old Dec 24, 2008 | 07:51 PM
swaybar's Avatar
swaybar
i agree, i think its a scam to make money, i'm surprised the dealers don't charge "19.95". and have the "oxy clean guy" market it.
Old Dec 24, 2008 | 09:15 PM
WhëëlMå1's Avatar
WhëëlMå1
Originally Posted by Bobby82490
X2^^
I have nothing pertinent to add to the thread....
but your avatar ROCKS. RIP Dime.
Old Dec 24, 2008 | 11:11 PM
442w30's Avatar
442w30
Nitrogen filled tires for aricraft is not uncommon as the exposure to high altitudes and extreme cold temperatures can mean a great difference in tire pressure. At normal ground levels the only thing that happens is your money leaves your pocket faster than normal. Keep a quality tire quage in your vehicle and check your tire air pressure every month will net you a larger saving than a nitro fill.
Old Dec 25, 2008 | 12:25 AM
DonsFx4's Avatar
DonsFx4
A little off topic...the reason aircraft tires use nitrogen is to eliminate any source of oxygen in the wheel wells after gear retraction. This stemmed from a Mexicana B727 that had a brake dragging on takeoff, resulting in extremely high temps, and when the gear was retracted it lost the ram air cooling. Tire exploded and caught fire...the theory being the compressed air in the tires helped fuel the fire.
Additionally, as noted above, compressed air contains moisture, and if this moisture were to settle in a particular area of the tire after gear retraction, then at altitude you'd get an ice mass...not a good thing to have an out-of-balance tire when landing at 160 mph!
But the main driver in aviation use is to eliminate oxygen (as well as moisture).
Old Dec 25, 2008 | 01:15 AM
YoGeorge's Avatar
YoGeorge
Interesting background, Dons...
I have also had vehicles in the past with chronic rim leak problems, in the earlier days of alloy wheels. I'm guessing that nitrogen fills in those would have helped reduce the corrosion on the rim bead area due to no water content.
That said, I have nitrogen in one vehicle, my E150. I bought the replacement set of Michelin LTX M/S's (same as OEM) from Costco and they put in nitrogen for free. It's worth every penny of *free.*
George
Old Dec 25, 2008 | 12:10 PM
JerrySC's Avatar
JerrySC
Not Enough Difference
The small amount of difference you would see in a car tire is hardly worth paying anything for it. Since normal air is 78 percent nitrogen, there isn't a lot of difference. Nitrogen is generally drier than air but rusting wheel parts don't seem to be a problem these days. Anyway, if you fill your tires from a compressor with a good filter/drier it's almost as dry. Aircraft use it because nitrogen isn't combustible but that's not a major deal in a car with non-enclosed wheel wells. Will it hold a more stable pressure longer? If you did the math, I don't think you'd open your wallet for the difference. It's just another gimmick like so many auto/truck items.
