Sensor? TSS OSS VSS???
Old Jan 7, 2009 | 02:24 PM
mx510's Avatar
mx510
My Od light was flashing too. I serviced the rear diff and cleaned off the sensor. Still did it.
So I noticed that it would blow the fuse when I turned on the AC. I looked under the hood and the wires coming from the plug on the compressor were touching some metal. Then I noticed a burn mark on the metal, so I guess it was shorting out right there. Moved the wires, replaced the fuse without another 10amp and drove it all day with no problems. Everything works, abs light is off, ac works, all the symptoms.
Old Jan 7, 2009 | 03:26 PM
superduty4x4's Avatar
superduty4x4
Originally Posted by bigcab
The transmission shop told me I needed a vss. Installed and now have speedo needle bounce. I filed the plastic sensor so it would sit deeper and pick up gear oil as the rear end turned. The bounce is less but still there and I still can't use the cruise control. I have checked and cleaned every connection and still have issues. The trans shop said that my next step replacing the speedo in the dash
Sounds like a PSOM issue (programmable speedometer/odometer module). PSOM is a small computer chip that sits behind the speedo... signal comes from VSS to PSOM, PSOM sends info to trans and engine based on signal from VSS. Bad PSOM = bouncy speedo, erratic shifting, no cruise, and if left long enough a toasted trans (tranny is going nuts trying to figure out what to do while the speedo is bouncing).
mx510- glad you found the problem.
Old Jan 7, 2009 | 07:44 PM
totin_tools's Avatar
totin_tools
Glad you found the problem. Thanks for sharing what the problem was. I think I might have jiggled some wires under the hood while I checked the oil. Maybe I fixed mine to.
Old Nov 12, 2011 | 10:21 AM
buckarette's Avatar
buckarette
VSS Problems
BigCab,
Did you find a solutions to your VSS problems you first posted about. I too am having along the same difficulties...
Rear end checks out, transmission checks out, replaced VSS at least 3 times in the last month, replaced pigtail for VSS.
Speedometer still jumping eratically, automatic trans shifting out of gear into neutral as you r driving. Anyone have a clue as to what to try next, I was told it maybe a instrument cluster or computer, but as of yesterday when I was at Ford, they are no longer making these parts...
Old Aug 10, 2013 | 04:38 PM
Josh Key's Avatar
Josh Key
tss and oss sensors
Can any body help me have a 2003 f350 6.0 4x4.tryed fixing speedometer. Replaced vss on rear end and still no speedometer. Also took out tss and oss sensors cleaned put back in.now truck wont start.any clues why thanks
krwg35
Mar 30, 2022 03:35 PM
varminthunter243
Mar 15, 2016 11:26 AM
krwg35
Feb 4, 2016 10:38 AM
radramrod2
Aug 15, 2015 08:30 AM
redsly
1997 - 2003 F150
Jul 10, 2012 07:39 AM
