I keep reading about this problem happening with the V10 engines. I have an 04' with the 5.4. Has anyone had this happen in the 5.4? I also read that ford "fixed" the issue in 03'. Any one have anything?
I believe this problem comes from over-torqueing the plugs. I had a 5.4 in my Expedition and never had hte problem after taking the plugs in and out a dozen times, never using a torque wrench, but i have put in a lot of plugs and kind of know what feels right. As far as I know, as long as plug maintenance is done right, you shouldn't have an issue. However other 5.4 owners might wnat to chime in with more info.
It's a problem with all 2V modular engines, the 6.8 (V10), the 5.4, and the 4.6L engines.
With the '03 model year, Ford started putting 8+ threads in the spark plug holes on the cylinder heads, which made the margin for torque error larger, thereby all but eliminating the blown plug problem.
As Jay stated, it's improperly torquing the plugs on the '02 and older, 4 thread spark plug hole heads that can cause the plug to eventually blow, if the torque is not corrected.
Stewart
PS - I blew a plug in my Lightning. Ever since then, I've checked my plug every 6 months and when I change my plugs, I do it with the engine cold, torquing them down to 12-13 ft lbs.
Stewart
Ok,
I'll keep that in mind. It's got 66,000 in it now, and I can only assume it's never had the plugs changed. Is there a giude that shows me the service intervals and certain mileages, so I know what to do from here on out?
The maintenance guide that came with your owners manual, if one came with the truck. If not, drop by any Ford dealership and ask them for a Ford recomended maintenance schedule for your truck.
I'm sure there is something online, but I've never needed to look for one online so I have no clue what the web address would be. Maybe someone else who has a place bookmarked will chime in.
