F-150 4x4 kicking out, diengaging,&or slipping
Working on my sons 1998 F-150 4.6L auto:
It has automatic hubs, electric shift Borg Warner 4406 transfer case
The problem is: whenever you really need the 4x4, or just flooring it, the
4-wheel drive disengages. Let up and it works for a bit then out again. Does it in HI or LOW range
You can jack up the front and it engages, can't spin the tire everything seams to be locked up like it should.
We have checked the vacuum lines and all appears fine. Changed the vacuum shift motor on the front diff & transfer case shift motor, didn't help.
Is there anything in the transfer case that can cause this or is it inthe front diffs vacuum system? Maybe one of the solenoids?
4x4 slipping
Check 2 items. First put a vacuum gauge on the hose at the front diff that engages the axle and rev the engine and hold it for a second or 2, the vac should stay the same. If it drops you have a broken vac line, defective check valve, or cracked vac tank. try running a hose to the engage port (at the axle) from inside the truck. Use a cheap hand vac pump to engage and see if problem goes away. If not most likely a defective/damaged engagement collar in front diff
Arizona97
03-18-2017 06:37 PM
johnnybecool
1999 to 2016 Super Duty
03-04-2007 12:51 PM
