Guys,
While I was installing my Banks Transcomm, I pulled out the wiring hornest on the driverside of the truck and notice the hornest appears tobe dirty. How do I go about cleaning this connector? If this connector isn't clean properly,will this cause any hesitation in the vehicle?
I'm assuming that you mean "wiring harness" If so then your best bet is to use some electrical contact cleaner. Make sure to read the label to make sure that it is safe dor plastics. IIRC Lectra Clean will do the trick.
"Description: CRC Electrical Parts Cleaner is a quick drying, non-chlorinated parts cleaner for particular use on heavy electrical equipment. Electrical Parts Cleaner does not contain Carbon Tetrachloride, Trichloroethylene, Tetrachloroethylene, Methyl Chloroform or CFC 113. Ideal for use on electric motors, generator and transformer windings, electrical parts, etc. Electrical Parts Cleaner swiftly and effectively degreases, removes oil, dirt, wax and other foreign matter without leaving a residue"
Thanks Jim. I feel kinda bad though. I was trying to go light on it but he logged off relatively quickly. Hope he's not mad at me. I didn't mean to offend him, just having some fun.
Zavierbr, I see you have not posted since this thread, and I feel bad if it because of me. I apologize if I offended you, and just want to say, do like most do and ignore me. I try to help folks as much as I can, but I also have fun from time to time. C'mon back buddy.
