Sponsored by: Kumho
replace rotors -Windstar Van
Old Dec 23, 2008 | 08:15 PM
fordguy21's Avatar
fordguy21
I need some direction on replacing a pair of front rotors on a 96 ford windstar, as the Chilton manual doesn't cover this.
From what I read its pretty straight forward, jack up, remove tire, remove and wire up caliper, remove lock washer holding on rotor, then rotor should be free.
When putting on new rotors do I just clean off rust and slide on, do i need to replace the lock washers that were on the studs, also should I put some anti seize on the back of the rotor so it wont rust together and get stuck, I'm I missing a step or is there something I should do in the process, any tips tricks, or techniques that one may share!
Thanks to all in advance
Old Dec 24, 2008 | 08:56 AM
Gevans17's Avatar
Gevans17
replacing rotors
check your private message Fordguy21
Old Dec 24, 2008 | 02:23 PM
fordguy21's Avatar
fordguy21
Thank you so very much and have a happy holiday
