Sponsored by: Auxito
4.2 help
Old Dec 23, 2008 | 06:40 PM
dirtracer2a's Avatar
dirtracer2a
4.2 help
My buddy has a 1998 F-150 4x4 with the 4.2 V-6, the truck wont turn over and he has been told that the truck has water on top of one of the pistons causing this.I havent looked at the truck since this has happened so I cant tell you what the mechanic has done to verify this, or if its just a guess. He told my buddy that these engines are notorious for cracked heads. Is there any truth to them having bad heads? If so where can he get a set of aftermarket heads?
My little brothers truck started blowing antifreeze out the side, he said it looks like its coming from the head gasket. This is making me wonder even more about the 4.2 heads. His truck is a 1999 F-150 2wd. Is this a common problem with these trucks? Thanks in advance
Old Dec 23, 2008 | 09:27 PM
fire240's Avatar
fire240
Chances are his lower intake manifold gasket is leaking water down into one of his cylinders.
Old Dec 23, 2008 | 10:35 PM
dirtracer2a
Thanks for the help. we have just came to that conclusion.
Old Dec 24, 2008 | 09:52 AM
kaboom10's Avatar
kaboom10
Put a socket on the bolt in the crank and a breaker bar or equivalent and try to move it. You could pull out all the plugs first to.
oldtired53
3.8 & 4.2L V6
Sep 25, 2006 08:58 AM
STX03F150
3.8 & 4.2L V6
Oct 18, 2005 09:27 AM
fixingbus
3.8 & 4.2L V6
May 6, 2004 06:19 AM
truckfarmer
3.8 & 4.2L V6
Jun 14, 2001 11:28 AM
