Ok, another dumb one
Old Dec 23, 2008 | 03:16 PM
jmmartin's Avatar
jmmartin
Lightbulb Ok, another dumb one
On the 87 6.9 t19, is it feasable to convert to 4wheel drive. Right now i am really ticked, just fixed my drive way, but it didnt pack in well enought yet. Truck wont go 1/4 way to highway. Caravan barely made it out, wife wont let me use the 4x4 jimmy, its "HER" car..... DANGIT!!!!!
Old Dec 23, 2008 | 03:52 PM
starmilt's Avatar
starmilt
Easier to get a new wife.
Cheapest and easiest way is to get a donor truck that is 4x and use your components but it can be done (time and money).
Old Dec 23, 2008 | 05:26 PM
Franklin2's Avatar
Franklin2
If you are going to 4x4, now would be a great opportunity to install a zf 5 speed overdrive tranny and 4x4 out of a 87-up diesel f250 or 350. The 4x4 is nice, and the overdrive is even nicer.
Old Dec 29, 2008 | 06:02 PM
jmmartin's Avatar
jmmartin
ok, lets say i came across a possible donor truck. BUT this donor is a 7.3 PS W/Auto trans and manual transfer case. Is this feasable? i dont want the auto, just the 4x
Old Dec 29, 2008 | 07:03 PM
starmilt's Avatar
starmilt
Are you talking a running donor or a parts truck. Is this a truck you want to swap your motor and body over to the frame or ???.
Old Dec 29, 2008 | 09:16 PM
Dodge/Cummins's Avatar
Dodge/Cummins
You'll need a 4wd transmission to use the x-case.
You could go with an older divorced NP 205 out of a Ford and use your transmission with custom drivelines. The trick thing to do is set the x-case up in the truck so the front and rear driveline are the same length. Have 3 of them made/modified and then you have a spare that will fit either end.
Make sure the x-case is a 205 and not some weird Dana 24, old Borg Warner or some other odd-ball.
The Ford frontends are better but you could go with a Dodge, GM, International or Jeep Dana 44 or 60 and one of those brand's divorced 205s also. It'd make people wonder why your Ford has the pumpkin on the wrong side.
NOW don't take this the wrong way BUT if you have to ask if this CAN be done it's probably not something you're going to want to take on. It is most assuredly NOT a bolt-in job.
Old Dec 30, 2008 | 09:09 AM
jmmartin's Avatar
jmmartin
hey dodge i knew it wouldnt be a easy swap, i have access to a Victor wrench, and all the Lincolon Glue i could ever need, lots of fab experience, and like to learn how to do new stuff. + im only 28, and like to have an arsenal of things i can do, ya never know whan ya may need to do in life, so i want to know how to do it all.
Old Dec 30, 2008 | 09:44 AM
fonefiddy's Avatar
fonefiddy
Google it. there's plenty of info on the swap out there.
Old Dec 30, 2008 | 10:03 PM
Dodge/Cummins
Have at 'er then. That's really all there is to it. Cutting, fabing and welding.
I would say that this is the place for the fabricators tendency to "over build" to kick in. You really can't make this stuff too stout.
Old Dec 30, 2008 | 10:08 PM
rupejosh's Avatar
rupejosh
tell me about over doing it.i found some 1/4" steel plate today at work im thinking about welding it on my frame to stiffen it up.why you ask?i have no idea i like things to be overbuilt i guess.
Old Dec 30, 2008 | 10:16 PM
starmilt's Avatar
starmilt
I'm still going to ask unless you plan on mounting a wrecker body or making a tough truck about the only reasons I can see.
Dodge why is the ford front tougher than the dodge frontend or is it the draglink steering components etc....
Old Dec 30, 2008 | 10:26 PM
rupejosh's Avatar
rupejosh
ya never know what i may end up doing a wrecker bed would make me some money good thinkin starmilt.hmm and i think i have a friend with an extra one too.........
Old Dec 30, 2008 | 10:30 PM
starmilt's Avatar
starmilt
I gave a nice one away last summer.
Old Dec 30, 2008 | 10:31 PM
Dodge/Cummins
STARMILT,
The Ford fronends are High-pinion and Dodge and Chevy are low-pinion (coast side).
The Ford pinion gear goes into the HIGH side of the ring gear (drive side) which is better and stronger for a FRONT application.
It also reduces the driveline angles.
Ford also uses a track bar on the Dana 60s in the '86 or so and up. I think the addition of that track bar is a highly UNDERATED component. I've never driven a GM or Dodge with a Dana 60 that tracks as straight.
Old Dec 30, 2008 | 10:39 PM
starmilt's Avatar
starmilt
You mean there is something about a ford that is better than a dodge hmmm.
I knew about the track bar and steering diferances but I hadn't thought about the high pinion verses low but as always you are 100% CORRECT.
