A 302 should have a roller-ready block, but may not have actually had a roller cam until 92. The 351 was flat tappet in 91, as well as the 300 six and 460.
I have a non roller block 347 I will be dropping in this truck and just needed to know if a hydraulic roller retro-fit kit and cam is needed for it to run with the computer. Thanks for the help.
I don't believe that the cam being roller or flat tappet would make a whole lot of difference on the stock computer calibration. The lift and duration characteristics would be the key factor, not to mention the additional 45 cubic inches. A custom tune of the stock computer or possibly a 351 truck computer would really be needed to make sure it runs with a safe mixture. I'm sure someone else can chime in with their favorite cam suggestion.
'91 truck should have been a roller block, the casting number will tell you for sure. You can put a roller cam in that motor and you don't need the expensive retrofit cam and lifters, the regular production lifters and retainer assembly will bolt right in. As Eric stated it's the cam profile that determines suitability for EFI or not, but if you don't have a mass air truck then this motor won't work very well with the existing computer at all.. doesn't matter what cam.
Well that's not an absolute, if the cam isn't to far from a stock grind, heads are stock or ported, then it will run on a 5.8 computer. But if you have aftermarket heads and a healthy cam you need mass air.
The cam will be one of the small computer cams but the motor has Performer RPM heads on it. I live in SoCal and need to smog the truck. So do I need the 5.8 computer and the mass air ? Thanks
Ouch!!! With those heads I think you're gonna need MAF cause even with a small cam the motor will move lots more air than a stock 5.8. You'll probably need it tuned as well to get emissions down to stock figures at idle and cruise.
