6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Spartan tune with DPF
Old Dec 22, 2008 | 04:08 PM
peefrog's Avatar
peefrog
Is anyone running the Spartan tuner with their DPF still on??? If so how is it working for u. (ie...response, smoke etc) Thinking of a Spartan but might start with the DPF on first. Baby steps first.....
Old Dec 23, 2008 | 03:33 AM
R-T0r21on's Avatar
R-T0r21on
I have the Spartan DPF-on tunes. I like it vey much. MPG gains are modest, but I do also have improved performance. No problem w/ smoke. Active regenerations are the same duration & frequency as before the tuner. I do also have the AFE CAI which made the biggest difference in the truck in reference to regens. Truck runs great. Hope this helps you w/ your decision.
Old Dec 23, 2008 | 07:20 AM
peefrog's Avatar
peefrog
thanks for th info...maybe pull the DPF off later but want to keep the warranty for now...
Old Dec 23, 2008 | 09:41 AM
wreckit72's Avatar
wreckit72
Once you put the tunes on then you comprimise the warranty with or without removing the DPF.
Old Dec 23, 2008 | 04:15 PM
R-T0r21on's Avatar
R-T0r21on
That's true, wreckit72. However, it's so much easier to switch back to stock if necessary by just reloading the stock tune than it is to do the hardware swap too. Also, you'll be all set for the upgrade when you feel it's time to do the DPF delete.
Old Dec 28, 2008 | 03:39 AM
powerstroked162's Avatar
powerstroked162
Spartan all the way. Matt had did the tuning on my truck, He's a class act all the way!
Cowboy Steve
Old Dec 28, 2008 | 09:36 PM
Moyerboy's Avatar
Moyerboy
im running the spartan tune im running the 210 tune with a true flow intake and 4 inch MBRP exhaust adn delete pipe but still hae to gut the cat but i love every moment of the tuner and wouldnt look back at the warranty
