f250 6.9 diesel engine problems
Old Dec 22, 2008 | 03:45 PM
deann's Avatar
deann
Question f250 6.9 diesel engine problems
i have a diesel 6.9 engine it wont crank on the first startup without being pulled off but after it warms up it will crank . i have changed out the glow plugs, sylnoid and switch. i have a fuel leak on the line to the injector i have to fix could that be my problem
Old Dec 22, 2008 | 08:52 PM
Franklin2's Avatar
Franklin2
Yes, the fuel leak could be the problem. It lets air into the fuel system, so the whole fuel system drains back to the tank and ends up being dry. You need to buy new lines and o-rings for the injector fuel return system. A o-ring on top of the injector is probably were the fuel is coming from.
