Engine block heater
Old Dec 24, 2008 | 07:51 PM
strickracing's Avatar
strickracing
ive seen some of the powerstrokes that come from factory with a plug threaded in where the block heater goes u pull the plug and install the blockheater if u want it
Old Dec 26, 2008 | 06:38 AM
FSJ-EARL's Avatar
FSJ-EARL
Well, we crawled under the truck, looked around and low and behold, there it was zippped tied and tucked up out of the way!
Old Dec 26, 2008 | 08:26 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
I'm thinking that you'll want to do this when you flush your coolant. IIRC the block heater heats the coolant, so it must therefore be in the coolant path, yes? So pulling that plug would let your coolant out of the block.
Old Dec 26, 2008 | 09:31 AM
fxstbchopper's Avatar
fxstbchopper
Very common place for it to be hiding.
FSJ-EARL
Jan 4, 2010 06:43 AM
eandaauto
Jan 11, 2005 09:09 PM
Earl
Jul 6, 2002 08:54 AM
Earl & Laurie
Dec 23, 2000 11:39 PM
