Headlight Replacement
Old Dec 22, 2008 | 01:44 PM
parkingman's Avatar
parkingman
Does anyone know if the single fixture light for later model super duty trucks will fit / replace the 3 pieces for a 99 model?
Old Dec 22, 2008 | 02:55 PM
ReAX's Avatar
ReAX
Do you mean the 05 conversion?
I am planning on doing the 05 conversion soon and will document it. I am waiting on connectors to come in. It's not a simple bolt on. The 05 aero headlights use a 9008 bulb instead of the regular 9007 Ford used, so the connector has to be changed. I am going to build a relay harness for mine, but the connectors are metripack 150, I bought the connectors, pins and plugs to do 3 lamps for $6. Once you have the parts, you need to cut up a section of the bulk head to fit the lamps. Then it just bolts in.
If you want a simpler upgrade, the 03 clear lamps bolt in pretty easy.
Old Dec 22, 2008 | 05:05 PM
parkingman's Avatar
parkingman
I guess i am talking about a conversion?? I had heard of someone saying an 05 headlamp would replace, but i didn't know if it was a simple bolt on or lots of modifications. Let me know when you post your conversion, I'd be curious to see how much work it takes.
thanks,
Old Dec 22, 2008 | 05:52 PM
ReAX's Avatar
ReAX
I make things more difficult than they have to be. Like I had said I am going to make my own relay harness. The basic install is posted here in the superduty forum I think and on several other forums as well. I'll put it in the superduty forum and try to remember to look this post up too.
Old Jan 1, 2009 | 11:22 PM
ReAX's Avatar
ReAX
I remembered.
I have one side done and I have a rough draft for the instructions. It's here http://sites.google.com/site/reax222...attredirects=0 until I get a better host.
SeaCarr
Aug 21, 2016 05:59 PM
Sanddriver
Apr 1, 2016 08:38 AM
tluns
1978 - 1996 Big Bronco
Feb 28, 2015 10:31 AM
fordboy67
Feb 23, 2015 10:28 AM
nmarlowe
Dec 1, 2003 04:15 PM
