Sponsored by: Kumho
Riding Rough...
Old May 25, 2001 | 08:22 AM
ubaney's Avatar
ubaney
Riding Rough...
For some reason, about 6 or 7 monthe ago, my truck started to ride rough (small holes feel like huge pot holes) and I also noticed that it rolled more around corners. I changed the shocks thinking that might help. Not at all. I've been told that bushings make all the difference in the world. Can I add a stabalizer bar to the rear to help with the rolling and if so, can I do it or does it require a professional? Please Help! Thanks a lot. UB
97 F-150 Extended Cab 4.6L Auto 3.55 LS
Old May 25, 2001 | 08:28 PM
billyb's Avatar
billyb
Riding Rough...
put in new bushings, and a stabilizer bar kit. it will make a big difference in handling. the stabilizer bars are fairly easy to install.
one question though. did you change tires or tire pressure around that time? i went from a 2ply sidewall to a 3 ply and it was a big change. much stiffer.
Old May 29, 2001 | 08:51 AM
85351ho's Avatar
85351ho
Riding Rough...
Old May 30, 2001 | 10:12 AM
ubaney's Avatar
ubaney
Riding Rough...
Billyb,
I did change tires but they are the same tire as the original. I also had a front end alignment.
UB
P.S. This is on a 97 F150 4.6 3.55.
