O/U 12ga vs pump 12ga
I'm going to be buying a new gun after the holidays for turkey and waterfowl hunting. I watch tv and they used a lot of o/u for waterfowl and was wondering what makes them better or is it just preference? I know they cost a bit more but I could probably find a nice used one in my price range. I have found a cheap 835 at walmart, its like $150 less than on the Mossberg website There is also a nice 870 at walmart for $2 cheaper than the 835. Which would be the better choice of the pumps?
on
You will get varying opinions on this so it will just come down to what your gut and pocket book dictates.
Personally, I prefer the up and down gun. I have a Ruger Red label and have been very pleased with it.
The up and downs offer less mechanical issues by the sheer nature of their design. When hunting in potential inclimate weather that should always be a consideration. In addition, it is easier to utilize different types of shot in each chamber. And you never have to be concerned about proper plugging of the gun. But, you have to be a bit more proficient. Only two shots available to you.
Pumps will serve you well. My brother is one of the fastest and most accurate pump shooters I know.
Don't eliminate the semi-auto. On a nice weather day most semi's will do well for water fowl.
I would be more concerned with the reputation of any given weapon brand you are looking at and using the correct selection criteria for the intended purpose. You may want to look a 30" barrel for turkey and waterfowl while I prefer a 26" for dove and quail.
No matter what you pick, the selction process is fun.
Good luck and be safe.
For me. . . for waterfowl, 870 pump.
Why???
THREE shots! (I need them!)
My O/U is a dove, pheasant gun and an 'informal' Trap gun.
You might even consider looking at the 870 "SuperMag".
For waterfowl and turkey, it'll handle those beastly 3-1/2" shells, plus, it'll handle the 'magnum' 3" and/or the 'standard' 2-3/4" shells.
My personal preference for all game is the 26" barrel, except for turkey and deer.
Then, something a little shorter. . .like a 20-22" barrel and X-Full choke for turkey and rifled slug barrel for deer.
As Keith said, don't rule out the semi-autos. I've carried my trusty Remington 1100 out on some of the nastiest days you would ever endure.
(Proper TLC after you get home is mandatory, though!)
i have both and hunt all sorts of waterfowl. and you cant go wrong with either gun. most states have a requirment to put a plug in your shotgun,so you will be limited to 3 shots. obviously the o/u will unload your 2 shells very fast. (i like that for my woodcock hunting)
i have a mossberg model 500a, 3 inch. got it in 91, has never once jammed on me, despite having a **** poor owner (me) in regards to taking care of it. keeps a very nice patter for turkey loads and birdshot. very accurate gun. has since been retired,to a deer slug gun (scoped)a few years back, and can throw a pattern at 100 yards in a pie plate with breneke ko sabot slugs 2 and 3qtr inch, is all i shoot for slugs
my o/u is a stoeger (ruger made i believe), has miss fired a couple of times on me,but absolutely love the gun, you feel zero recoil with 7.5 bidshot coming out of it
OK, I set myself up for that one!
It's a Browning 325 Sporting Clays Grade II. It's real purdy and I intend to keep it that way Keith!
My Browning BPS gets the most hunting duty. I'd like to get a semi-auto as the Turkey loads can get brutal when used for squirrels and crows all day.
