Any '68-'74 Econoline folks here??
Old Mar 22, 2018 | 10:26 PM
  #31
maples01's Avatar
maples01
I don't like 14's, they aren't readily available at tire shops, I upsized to 15" rims choosing a 225/65 R15 which is the correct overall diameter with the G78R14 that came on them.
Old Mar 22, 2018 | 11:52 PM
  #32
Practicalman45's Avatar
Practicalman45
Originally Posted by mikede1221
Hello To all,
I have a 1973 Ford Econoline E300 that has been passed down to me. The vehicle has been in my family for 45 years! I have been working on it for some time now. And am ready to purchase new tires. However, I am having trouble locating the right size as well. Any comments are suggestions is very much appreciated!
Thank you very much!
Since your van has 8 lug wheels (that were originally for 16.5" tires) I'd suggest 16" stock steel rims. They will fit, and if you get
Ford 16" wheels you can also snap on your original "dog dish hub cap" wheel covers (which will fit both 16" and 16.5" rims). 16" radial tires are available in a wider range of sizes and are more are affordable than tires for the rims. Be sure to choose LT (light truck) type tires of load range "D or E" (8 or 10 ply rating) because there are 16" car tires that you could put on there, but I wouldn't recommend that....
The 16" tires will probably carry metric size designations rather that the original inches sizes. Just ask your tire dealer to match the metric equivalent to the original inch size width and aspect ratios.
Old Mar 23, 2018 | 03:36 AM
  #33
vettex2's Avatar
vettex2
reminds me of the old Ironsides TV series
Old Nov 14, 2018 | 08:45 PM
  #34
mikede1221's Avatar
mikede1221
FORD 1973 ECONOLINE E200
Thank you so much for the feed back!! I was able to locate some good tires. I have been having over heating issues with the van . I tried to replace as much parts as I can, including the radiator. But once i hit some traffic on the free way it starts to over heat again. Any ideas what I do to help this problem? Thank you all for the feed back!
Old Nov 14, 2018 | 09:52 PM
  #35
maples01's Avatar
maples01
Radiator replacement is NEVER going to correct it, they discontinued the heavy duty radiators, the only one sold now goes to the inline six and is marginal at best, you need to get one built, I've tried to find the stock HD radiator and has been a waste of time, many are using an aluminum radiator built for big block Chevys from 1960's cars. https://www.ebay.com/itm/162233873360?ul_noapp=true
I live by the Smokey Mountains, I've tried everything, will never go electric fan, burned one up from a company that builds race cars and runs them, went with a 6 blade flex fan, awaiting warm weather next year to swap the radiator yet again with the aluminum one for a Chevy.
Old Nov 14, 2018 | 09:55 PM
  #36
maples01's Avatar
maples01
This is what you should have, a 3 core one of these will be far ahead on keeping cool, it came in AC vans and heavy tow applications, it's the only option.
Old Nov 23, 2018 | 08:42 PM
  #37
Resto Guy's Avatar
Resto Guy
Mark,
Has Ross in Florida contacted you about the heavy duty radiator in the van he bought from me a couple of months ago? He agreed that he would send the radiator to you in exchange for your help getting this van from me. I wanted to be sure that you got that radiator.
Let me know please.
Steve
Old Nov 23, 2018 | 09:50 PM
  #38
maples01's Avatar
maples01
Yeah, I gotta setup something with him, thanks.
Old Nov 25, 2018 | 10:10 AM
  #39
rpriccardi's Avatar
rpriccardi
rpriccardi
I'm an owner of a 72" ford econoline. Looking for pop out window seals for my back & side windows for the inside and outside windows.
Old Nov 26, 2018 | 04:12 PM
  #40
maples01's Avatar
maples01
You'll have to find a van with some to salvage, there is no one reproducing them, a guy on FB did some cleaning and reconditioning some for his recently.
Old Nov 26, 2018 | 05:16 PM
  #41
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by rpriccardi
I'm an owner of a '72 Ford Econoline. Looking for pop out window seals for my back & side windows for the inside and outside windows.
Upper pic: Type the basic part numbers for the weatherstrips you want, I'll see if anyone has any NOS
Old Aug 22, 2020 | 12:14 AM
  #42
Ray Yoshida's Avatar
Ray Yoshida
What size engine. If you tried all the usual suspect (radiator, thermostat, water pump) you may want to check if there is any head gasket problem or other leak from the engine.
Old Aug 22, 2020 | 12:20 AM
  #43
Ray Yoshida
Can anyone either send a picture or tell me the color code order for the voltage regulator on a 1970 E-100? I have the wiring diagram but it does not tell the connector positions. A couple of wires broke from it and now I don't know if I replaced them correctly since I have a voltage leak somewhere that is causing my battery to run down. It has 4 connectors and 5 wires. Thanks
Old Dec 27, 2020 | 11:41 AM
  #44
waltharper's Avatar
waltharper
Just bought a 69 E200 yesterday. $250 Of course it does not run. panel on drivers side and windows on passenger side. inline 6, 3 sp on the tree.
That is about all I can tell you about it. It needs a lot of "TLC", a whole lot. lol
But there seems to be very little rust I think, and just a little body damage on the passenger side which I think it will be easy fix.
The drivers front wheel was frooize up, brake drum only and itis missing the intake and exhuast manifold. I ahve not looked under it to see what rear axle it has or what gear ratio is in there.
It will need a new paint job. Looks like some one tried to brush paint on it. It looks like it has army green on it for the main paint.
The door hinges need to be replaced.
It is raining outside so it will be a few days before I can get in to see if there is anything specail about this rig.
HInts or suggestions will be welcomed. I will down load pictures when I get them.
Old Dec 27, 2020 | 11:43 AM
  #45
waltharper's Avatar
waltharper
Try rockauto for parts
