tranny not whating to shift
Old Dec 21, 2008 | 07:09 PM
joe f350's Avatar
joe f350
it has a 1500 miles on a rebuld the prolbme is i have to forced it in there up shifting of down shifting it real bad in the moring dont thinks its the clutch had that replace when tranny was rebiuld y is this happend is it a quick fix of a trear down cound my lift cause its half and half and sprins a blocks 4 inch spring 4 inch block all sping in frontplz help o 1 more thing to tranny fluid the shop put in was green with black speacks
Old Dec 21, 2008 | 10:03 PM
starmilt's Avatar
starmilt
Nothing wrong with the green gear oil I dont know what the black specks is though unless it is traces of the old gear oil they dont stick to a magnet do they.
Old Dec 22, 2008 | 12:02 AM
joe f350's Avatar
joe f350
haven check but i will i dont think they where metal flakes
Old Dec 23, 2008 | 04:27 PM
ford trans tech's Avatar
ford trans tech
depends on which trans which lube was installed and how cold it is in the morning
Old Dec 23, 2008 | 05:37 PM
starmilt's Avatar
starmilt
He has a T19 I;m no expert but the only green gear oil I've run across has been syn 50 wt he lives in the gay bay area so probably not to cold.
Old Dec 24, 2008 | 12:55 AM
ford trans tech
then it sounds like a clutch issue
