no forward or reverse
Old Dec 21, 2008 | 05:59 PM
the5martens's Avatar
the5martens
2005 explorer no forward or reverse. Dosn't show any codes key on engine on but will not complete a key on engine off test and no codes in memory.
Old Dec 22, 2008 | 08:53 AM
jk080's Avatar
jk080
Transmission Rebuilder
fluid level?
with engine off check fluid level, then start engine and compare, if its the same then the pump has failed.
Old Dec 23, 2008 | 08:57 AM
Steina's Avatar
Steina
CO River Rat
'05 Explorers have no tranny dipstick.
Steve
Old Dec 25, 2008 | 12:01 AM
the5martens
Thanks for your coments. Ya no dip stick need to check from the plug in the pan I have not done that yet to see if the fluid is burnt. The explorer drove fine before this happened, drove it into the garage one day no slips, leaks or noise and the next day no forward or reverse. Anymore ideas?
Old Dec 25, 2008 | 09:38 AM
tommyleea's Avatar
tommyleea
Does the shifter seem to operate normally? Sounds like maybe a linkage problem. Not sure how the linkage works on that vehicle. Is it a mechanical linkage? Have you looked underneath yet? Merry Christmas
