That plow is putting more stress on the steering, so it could be the leak, but the front passenger side could be the steering or the tranny cooler lines.
I bet it is coming from the 8 inch long rubber hose that connects the metal lines just under the radiator on the passenger side. Its a couple of hose clamps and a new peice of hose. So, its inexpensive to fix. Make sure you get fuel line hose. I tried to fix mine with regular hose for the radiator/heater and it didn't hold up to the fluid. I put a peice of fuel line hose on it a few years ago and it has done a great job.
