Sponsored by: Real Truck
brake roters
Old Dec 21, 2008 | 11:17 AM
budman325's Avatar
budman325
brake roters
what the best way to remove front and rear disc brake roters on a 2004 f350
Old Dec 21, 2008 | 01:49 PM
ReAX's Avatar
ReAX
Jack the truck up.
Jack the truck up, unbolt the wheels, remove the calipers. There shouldn't be anything left holding the rotors on other than a little crud.
Old Dec 21, 2008 | 02:28 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Rubber mallet the backside if theyre stuck-ish
Old Dec 21, 2008 | 08:40 PM
dmp437's Avatar
dmp437
Remove the calipers and hang them so there is no stress on the hoses. Calipers mount with two bolts that screw into the caliper pins which should move freely.
Then remove the caliper mounting bracket which is held to the axle with two bolts. Once the caliper mounting brackets are off the rotor should (in a perfect world) slide off. Frequently they do not. I did my rears on Tuesday and the only way the rotors came off is with a 8 pound sledge hammer. The rotors were the originals and the truck has 95k miles on it.
