too many rpms
Old Dec 21, 2008 | 01:52 AM
van o's Avatar
van o
too many rpms
when i drive my truck with 33in tires at 60 mph the tach says 2900-3000 rpms witch would mean i had somewhere in the neighbor hood of 4.80 gears witch it doesnt it has 3.54. so who thinks that whoever had this truck before put a 6cyl tach in?
Old Dec 21, 2008 | 01:57 AM
85e150's Avatar
85e150
Could be. Some tachs have a switch. Pull the tach, look at it, see if the back comes off, if there is a switch, etc. Then check the manufacturer's web site for info on how to calibrate for 8 vs. 6 etc.
Or, get another tach.
Calculators here, you can put in your axle, OD ratio, etc.
Novak Conversions - Gearing & Gearing Math for Jeeps
Old Dec 21, 2008 | 03:55 AM
van o's Avatar
van o
it has the factory tach in the dash.
Old Dec 21, 2008 | 06:08 PM
85e150's Avatar
85e150
Well, you can either pull that and replace with one for an 8, or punch it out, tape it over, whatever and buy a different tach.
Check it against a known good tach first--
Old Dec 21, 2008 | 06:27 PM
uncle.stosh's Avatar
uncle.stosh
With 4.10 gears that is exactly right.
My truck has 4.10's and 33's and I turn 3000 rpm @ 65 mph. Time for a 5 speed me thinks. I actually get better mpg in the city because of the lower speed and rpm's.
BTW, you are actually going much faster than you think. You need to go up 1-2 teeth on the speedo gear to fix it.
Old Dec 21, 2008 | 06:50 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
The 6000-RPM Factory tach was used in both 8 and 6 cylinder trucks.
When used with a V8 there is an extra ground hooked to the "8" terminal of the tach through the cluster printed circut.
On 6 cylinders this "8" terminal ground is left ungrounded.
Old Dec 22, 2008 | 12:58 PM
van o's Avatar
van o
i pulled the cover off the diff and it does have 3.54 gears it 46 teeth on the ring gear and 13 teeth on the pinion gear
