coolant problem?
Old Dec 20, 2008 | 09:29 PM
paintslinga2010's Avatar
paintslinga2010
coolant problem?
How many gallons total do you guys put in your radiatior.
When i filled my truck up after the cam swap it took 2 1/4 gallons of 50/50 mix. The stuff was junk so i drained it, pulled my heater core, flushed it out, then went to fill the radiatior back up. I dont think i even got a whole gallon of coolant+water in before it was full. I started the truck and ran it for about 2 min and shut it down and let it cool off. When i looked it was still full. Whats the deal?
Old Dec 20, 2008 | 11:09 PM
05chop's Avatar
05chop
This is what i would do! Remove the radiator cap install a pressure tester pump it up to 10psi wait 30 seconds.Remove devise look into radiator if its still full then remove antifreeze then start over.
Old Dec 21, 2008 | 08:23 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
It depends on the cooling system you have....
Capacity's (in quarts) are available on this site.
Pull the heater hose off the intake manifold, then fill it up.
This is not blocked by the closed thermostat.
At least then your block and waterpump will not be airbound.
Old Dec 21, 2008 | 08:36 AM
05chop's Avatar
05chop
Works for me every time!Plus its good to pressure check your work!
Old Dec 21, 2008 | 12:57 PM
paintslinga2010
i pulled the heater hose off and heard a big whoosh, then got another gallon or so in, so i think im good. Took the truck for a test drive and steam went everywhere, i cracked the heater hose when i pulled it off.
Old Dec 21, 2008 | 01:31 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Ooops!
Maybe you ought to change both heater hoses if they're so brittle or soft that it was damaged just removing it?
I'm glad to hear it worked out for you.
Please remember to check that it's full (cold) and there is still some left in the reservoir over the next few days as more air may "burp" out of the system.
