ok i poted a week or so ago about not being able to start my 86 f250 i thot i wasnt getting power to my glowplugs but i checked each plug is getting 12.73 volts but my truck still wont start without ether its in a garage that is about 70 degrees i dont have a regular test light i have a meter so idk how to check my glowplugs with that but all my glowplugs have less than 30 starts except one its kinda old so should i replace it? it worked just fine a few weeks ago and if only one glowplug is bad would that affect the entire motor?
Is your meter digital?
Does it have a resistace scale probably labled ohms?
If so, set it on the lowest ohms scale, remove the wire to the glow plug, touch one probe to the glow plug terminal and the other to the glow plug base.
You should see a reading of .5 to 1 ohm, but if the meter is a very inexpensive one it may read 0 ohms.
If the meter flashes, the connection is open, burnt out glow plug.
Caution, when the meter is set to resistance scale, voltage applied to the probes will blow the meter fuse or worse.
Probably a good idea to remove the battery grounds before you start.
which goes to the terminal the positive or negative? and ohms is the horsewhoe looking symbol right? i have a setting of 200k up im not sure if 200k is the lowest or if 200 is cause there isnt a definate line between ohms or the other setting. and if one glowplug is bad could that prevent the motor from starting even if the other are good?
When reading ohms it doesn`t matter which is pos or neg. And yes ohms is the horseshoe symbol. Set the meter to 200 not 200k.
Are you confident you do not have an air lock in the fuel system?
yah i would check all the return lines and filter area for any sign of fuel arund them i had the same problem and mine was leaking right behind the breather on the hose going to the tank. and i could not get mine started eather it would just turn over after like an hour it would finley start
When you get the meter set on 200, touch the leads together. That's pretty much zero ohms, and that is what you are looking for when you touch the ground part of the glowplug, and the terminal part. They should be connected just like when you touched the leads together. Make sure you unplug the wire to the glowplug before you test it.
ya all of my wires were unpluged when i took the readiing i was checking to make sure they were all getting power beforfe i looked at my glowplugs to b the problem
ok i jus checked my glowplugs and the meter didnt do anything it read 1. never changed. and if my plugs were drawing power then if i tested the power on my batter would it read less when they were on?
With all glow plugs in good shape, my aftermarket volt meter on the dash drops to around 10 volts.
Dash lights dim if I have them on.
If the heater motor is running, it slows down a noticable amount.
ok my lights dont dim when i turn my glowplugs on and this just came up when i tested to see if i was getting power to them i grounded it to my battery when i tested each glowplug wire is that where i shoiuld have grounded it or should i have grounded it to my glowplug itself?
mine is melted i just got the wires back to their places and i pet the positive end to the terminal that goes over the glow plug and i grounded the negative end to the negative battery post woould that give me an accurate reading of how much power my glow plugs are getting?
