Clearing a CEL
Old Dec 19, 2008 | 08:20 PM
goofin's Avatar
goofin
Clearing a CEL
Had to replace the post cat o2 sensor to pass PA emissions test. i have a few weeks yet to get it retested. one mechanic said to clear the code then drive it to turn the monitors on to pass. another says after about 20 start, run, shutdown cycles, the light will go out if the problem has been solved. i have a sct x3 so i can clear it so what method would you guys use?
oh yea, its a 98 4.0 5speed with well over 225k on it
Old Dec 19, 2008 | 08:44 PM
drb1956's Avatar
drb1956
I'd think that once you clear it with the scan tool, you should be good to go..I've cleared codes with my scan tool, and never had a problem with the smog test!!! If you remedied the source of the code, you've cleared it out, driven awhile, you should be OK..maybe another opinion is good thing though....
Old Dec 19, 2008 | 11:19 PM
michigan66's Avatar
michigan66
The poor person's method is to disconnect the battery for half an hour or so, then connect it again. Some say leave the battery disconnected overnight. Your engine may run rough for a bit when you start it after doing this, but after a few miles the computer will relearn the proper settings and the engine will smooth out.
Good luck.
Old Dec 20, 2008 | 12:05 PM
97ranger xlt's Avatar
97ranger xlt
yeah you have to do a few starts/shutdowns before you take it back to emissions for the re-test, so the OBD system is 'ready'. not sure if it's 20 times though... sounds like a lot..
Old Dec 20, 2008 | 06:50 PM
goofin's Avatar
goofin
after driving 60 miles after resetting codes it now showing a p1151 and a p0155.so it looks like ill have to just buy the other 2 and be done with it
