sputtering
Old Dec 19, 2008 | 06:29 PM
trucker41's Avatar
trucker41
sputtering
83 6.9 Started sputtering then will run fine. Sputter then run fine. Plowing snow tonight it surged a couple times then staled. could not get it started again. Mess with it some more in the morning. I,m going to change the fuel filter hope that cures the problem.
Old Dec 19, 2008 | 06:39 PM
joe f350's Avatar
joe f350
maybe ur ip pumps is dying and of dead
Old Dec 19, 2008 | 06:55 PM
David85's Avatar
David85
How cold is it over there? Fuel gelling would be my first guess.
What is the fuel level in the tank?
Is it stalling when you let off the pedal at 1500 RPM?
Old Dec 19, 2008 | 06:57 PM
starmilt's Avatar
starmilt
Sounds like an air leak some where before the lift pump.
Old Dec 19, 2008 | 09:40 PM
Dave Sponaugle's Avatar
Dave Sponaugle
With some of the temps I have seen listed up in that area I would suspect gelled fuel first.
Old Dec 20, 2008 | 04:00 AM
trucker41's Avatar
trucker41
It is 3f right now guess I didn't think about gelling. It has been in the teens to low 20,s last few days. The truck was idleing when it stalled. Fuel tank is full,that is the first thing I thought. Been there done that.
Old Dec 20, 2008 | 06:45 AM
fonefiddy's Avatar
fonefiddy
I wonder why there have been so many fuel probs? Most suppliers KNOW it gets cold in the winter. Seems like their dropping the ball with the winter fuel supply?
Old Dec 20, 2008 | 10:45 AM
David85's Avatar
David85
One of our diesels had fuel gelling and it was a lot warmer than 3F. shot the fuel filter with a heat gun for a few seconds and it was good to go.
Old Dec 20, 2008 | 11:37 AM
trucker41's Avatar
trucker41
put a propane blower heater under the truck rapped front of truck with plastic for two hours still no start. Took off line from lift pump to filter no fuel. Waiting for my wife to get back with new lift pump. Hopeing this cures my problem.
Old Dec 20, 2008 | 12:31 PM
Dave Sponaugle
I was reading the other night when a gelled fuel issue came up.
ULSD has a third classification WDO or wax drop out in addition to CP and CFPP.
Looks like WDO may be a bigger issue than CP and CFPP with ULSD.
Here is the article.
CFPP vs CP
Old Dec 20, 2008 | 06:17 PM
trucker41's Avatar
trucker41
put lift pump on started up ran like a champ. Son took it to plow his driveway said it stalled on him a couple times. Maybe i will put some diesel kleen in it.
Old Dec 20, 2008 | 10:52 PM
S.P.'s Avatar
S.P.
I live in Vancouver, Wa. and I run fuel conditioner/anti gel, and its only in the 20s to low 30s...
I also run trans fluid year round...
Old Dec 21, 2008 | 05:59 AM
trucker41's Avatar
trucker41
well back to square one truck died on son last night. I took it for a 10 mile drive, (after new filter and lift pump)Ran super good son took it to plow his driveway stalled couple times,then on the way back to my house it died and would not start. So going to put diesel kleen in it. If that doesn't help I am going to put new fuel line from tank to lift pump.
Old Dec 21, 2008 | 06:42 AM
fonefiddy's Avatar
fonefiddy
Are You sure You got the lift pump arm on the cam correctly?
Old Dec 21, 2008 | 12:32 PM
Dave Sponaugle
Yes there are specific directions for installing the straight arm lift pump, they must be followed to the letter or lift pump and/or engine damage may result.
If gelling is the issue, the fuel may not be getting to the lift pump.
Chuncks of wax can and will stop up the fuel lines, filters and strainers.
Possibly you had the shop warm enough to dissolve the wax, when you pulled it back outside the fuel gelled and stopped the lines up again.
I watch the Weather Channel a lot, if you are in that brutal cold air mass, I think gelling is your issue.
