2WD Low
Old Dec 19, 2008 | 05:57 PM
crown180's Avatar
crown180
2WD Low
Hello, I have seen this mentioned a few times in the towing forum and just wanted to ask a quick question.
With the manual hubs unlocked/free, place the truck in 4wheel low - is there any risk of damage? This really sounds like a great thing for backing up the fifth wheel, nice little slope to get into the driveway.
Thanks
Old Dec 19, 2008 | 06:18 PM
rebocardo's Avatar
rebocardo
No, I do it all the time. If I have to pull a very heavy load up a hill on the street with my little truck, I even use it then. Of course top speed is 35-40 MPH in 4 low
I currently have open diffs front and back and will use 4LOW 4x4 to get started and will push in the clutch once the truck gets going to relieve stress.
Old Dec 19, 2008 | 09:47 PM
Ryan50hrl's Avatar
Ryan50hrl
nope...your fine...
Old Dec 19, 2008 | 10:55 PM
Old93junk's Avatar
Old93junk
Its one of the best ways of pulling a heavy boat up a steep ramp, I do it all the time with no problems.
Old Dec 19, 2008 | 11:55 PM
hanklin's Avatar
hanklin
Why not just use 4 wheel drive? Going thru same motions,right?
Hanklin
Old Dec 20, 2008 | 12:40 AM
Old93junk's Avatar
Old93junk
Too lazy to get out and turn hubs! LOL, just doesnt require the 4wd to pull a boat up a ramp, but works a hellva lot better than 2wd hi.
Old Dec 20, 2008 | 06:40 AM
hanklin's Avatar
hanklin
Oh
Hanklin
Old Dec 20, 2008 | 07:30 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Hanklin
4WD on dry pavement is not good with hubs locked in. All my vehicles which are older, will lockup and almost impossible to shift back to 2WD without jacking them up and freeing the hubs.
Old Dec 20, 2008 | 04:36 PM
hanklin's Avatar
hanklin
Hadn`t thought of that, thanks for the schoolin gfw
Hanklin
Old Dec 20, 2008 | 06:53 PM
crown180's Avatar
crown180
Thanks folks, will be sure to give a try this spring backing the trailer.
Old Dec 20, 2008 | 09:12 PM
2 stroke man's Avatar
2 stroke man
also engaging the hubs makes turning hard
Old Dec 26, 2008 | 03:38 PM
mike93's Avatar
mike93
The owner's manual for my '90 F150 even suggests doing just that
Old Dec 26, 2008 | 07:25 PM
Ford_Six's Avatar
Ford_Six
You can't do that on your truck- Super Dutys have two positions for the hubs- locked and auto. You'll be in 4x4, but for a short jog up a ramp that should be ok. If it binds up and is hard to get out of 4x4, take your foot off the brake and turn the steering wheel side to side while pulling on the t-case shifter. It should just pop out and into 2wd without too much trouble.
Old Dec 26, 2008 | 09:46 PM
PatsPOS's Avatar
PatsPOS
I'm showing my ignorance of new model options, I think...did Ford, in their infinite wisdom, decide to get rid of the manual hubs? I know for a fact that in '04 you could indeed get true manual hubs...they were marked "free" and "lock", just like the old-time Warns. I just don't know what Ford has done for hubs since then.
Pat
Old Dec 28, 2008 | 08:38 AM
galaxie641's Avatar
galaxie641
As far as I know they did. We have a '93 that originally had the auto hubs in it, aside from not being able to use 2wd low it also locked into 4wd about 5 seconds after you already got stuck.
