Brake Problem I've Never Read About Here
Old Dec 19, 2008 | 05:01 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
Originally Posted by guzzle92
DOT brake fluid is hygroscopic, meaning it sucks any and all moisture it can out of any air it can get to (reservoir mostly). Many mechanics, including Kwik, recommend flushing your brake fluid annually.
The brake lines require DOT3 brake fluid. Power assist (hydro boost) requires tranny fluid.
That's what I thought Guz, thanx for clearing that up for me, and everyone else.
Old Dec 19, 2008 | 05:50 PM
Kwikkordead's Avatar
Kwikkordead
Yeah, bleed the brake a minimum of every other year, regardless of mileage.
I also recommend using DOT4 it is designed for disk brakes.
I think DOT 3 will work ok but the boiling point is lower than 4 and disk brakes make more heat than drum.
I just get DOT 4 for everything, that way I know that it will meet the standard.
Old Dec 19, 2008 | 06:11 PM
Meatco1's Avatar
Meatco1
Also, I had a problem with the pistons on one of my trucks. It seems the pistons in the calibers had a large supply of rust on them, and each time I stepped on the brakes, they wern't retracting.
Kept me wondering what in the heck happened to my mpg, why it was taking so much go juice to get started, and ended up having to buy new rotors, & calibers.
Just a thought,
Richard
Old Dec 19, 2008 | 06:50 PM
preppypyro's Avatar
preppypyro
Subscribing.
Old Dec 19, 2008 | 06:56 PM
Markadeck's Avatar
Markadeck
Just a thought,
Richard
Most of us here have been there, done that. In fact I went through 2 left rear rotors in one week because I tried rebuilding the calipers myself. I should have just bought a new caliper in the first place.
Old Dec 19, 2008 | 08:41 PM
King0581's Avatar
King0581
Subscribing also. No real input other then whats already been said.
Old Dec 19, 2008 | 09:32 PM
whjco's Avatar
whjco
I had a problem like this in an E250 van I used to own. There was a problem with the cups in the caliper assemblies that were keeping them from retracting. As heat built up in the pads and was transferred to the calipers, the brake fluid got hot and vaporized thereby pressurizing the brake system and setting the brakes up even harder. New calipers, rotors and pads fixed the problem. I also replaced the flexible hoses since they were subject to the heat.
I've also seen this happen when the flex hoses go bad and the interior liner flakes away and creates a restriction in the hose. It sort of acts like a check valve in that foot pressure will force fluid around the restriction but there isn't enough back pressure to fully release the calipers.
Either way I think I'd do calipers, rotors, pads and hoses.
Old Dec 19, 2008 | 10:10 PM
camodown's Avatar
camodown
Have you checked the hydroboost unit itself? When they go bad they can apply the brakes for you at random... kinda weird when the truck slows itself down and the brakes weren't applied...
Old Dec 22, 2008 | 02:52 PM
Markadeck's Avatar
Markadeck
Only reason I've not updated y'all is because I can't get hold of the boy. If he's got it fixed and has not reported to me he is going to have to become a member to get anymore help.
Old Dec 22, 2008 | 04:53 PM
eagleridge5's Avatar
eagleridge5
sounds like you need to rebuild or replace the master cylinder.
Old Dec 23, 2008 | 07:49 AM
vettdvr's Avatar
vettdvr
Originally Posted by Fordbronco69
Maybe the master cylider???
Thats the only thing I can think of that would cause the pressure to stay in the lines.
Has he done anything with the brakes recently? or did it just start happending all of a sudden?
I've read about when you collapse the pistons back inside the caliper you can damage some sorta valve in the master that would let the pressure release.
Does the brake fluid look dirty?
Also...are you saying the pedal is HARD to push down about after an hour of driving? Might even be a hyrdoboost issue.
Aff....slow typer
I have had a problem like this on a 76 ford f150 and a 92 Lincoln. The problem was the master cylinder allowing fluid to pass. This was caused by the vacuum booster failing applying pressure on the master cylinder. On the diesel I would suspect the master cylinder/hydrobooster. But verify there is no pressure on the brake pedal. If it is depressing even a slight amount it will cause the brakes to activate. I would not suspect ABS on this. So for my $.02 I would go for the master cylinder booster.
