Deep Snow
Old Dec 18, 2008 | 07:22 PM
96 F150's Avatar
96 F150
Deep Snow
Was up hunting last weekend and got my truck stuck in the snow. Snow was around 14" with some ruts in it. Truck is a 2004 F-150 xlt 5.4 4x4 with 2" AS level kit and 285 BFG at's on it. I was a little disappointed in teh performance with the truck especially when watching my cousins 01 with 4.6 and 285's wheeling doughnuts around me. I have the tires pumped up to around 55psi so not sure if letting some air out would have helped or if I am going to need to invest in a locker. Has anyone else ever had a problem going thru deep snow???
the worst part was there were about 5 chevy guys watching this whole episode
Old Dec 18, 2008 | 07:45 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
it isn't hard to get stuck in snow...especially deeper snow if you don't know what you are doing.
btw, less air pressure is better in mud and snow
Old Dec 18, 2008 | 08:19 PM
N3mo's Avatar
N3mo
at 55 PSI, I'm supprised you got to the snow, let alone into it. Air down! Then, very light throttle. Saw the steering wheel back and forth a bit, and apply the brakes lightly in a poor mans locker.
Old Dec 18, 2008 | 11:48 PM
ChargersFanInCO's Avatar
ChargersFanInCO
I've gone through 2 feet of snow with mine...2 feet, off-road. Handled fine considering what I was in. 4L, and light throttle. Steady speed.
Old Dec 19, 2008 | 12:01 AM
bullredguy's Avatar
bullredguy
finesse is the key and take those heavy boots off its hard to feather a throttle with snow pacs on
Old Dec 19, 2008 | 12:21 AM
brianjwilson's Avatar
brianjwilson
Wow, yeah, lose some air pressure.
When I would take my sport trac in deep snow (18+") I would air down to 12-15 psi.
A locker or limited slip will help a ton, for sure. Open differentials are horrible for anything other than dry pavement.
Old Dec 19, 2008 | 12:27 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I personally would recommend a LS...lockers aren't really suited for daily drivers. Awesome offroad...but the road manners aren't exactly ideal.
I had 2 F-150's in the driveway for about 6 months for the 06 winter.
A 94 and my 06. Both were 4x4, but the 94 had an open diff with 3.55 gears.
It snowed about 8" one night. I went out in the morning to go to work in the 94 and couldn't move more than 2-3 feet.
Hopped into the 06 and had 0 problems. The LS works wonders. The open diff in my 94 made it useless in poor traction...even when in 4x4
Old Dec 19, 2008 | 12:32 AM
Ryan50hrl's Avatar
Ryan50hrl
don't take advise from the guy who lives in pearl harbor...how much snow they get a year?? LOL...just kiddin
Old Dec 19, 2008 | 12:51 PM
brianjwilson
My sport trac had aussie lockers (automatic lockers) front and rear. Aired down to 10psi in deep snow was no problem, just plowed right through stuff with all four wheel pulling hard.
I actually didn't mind the aussie locker on a daily driver. It sure made slick roads fun and was great for drifting . Install was easy (if you can do brakes you can do it), only costed around $260 per axle. My tires didn't like it as much, but still got quite a bit of life from them. I don't think I would run an aussie though with expensive 18" tires.
Old Dec 19, 2008 | 02:46 PM
N3mo's Avatar
N3mo
I have a 2001 Jeep TJ (Wrangler) with 33X 12.50-15 Mud tires. I air down to 12PSI for rock crawling and about 8-10 for snow. I have a detroit locker in the back and a tru-trac limited slip in the front. Not the greatest rig to drive in the snow on a highway, but it sure is fun
Old Dec 19, 2008 | 04:41 PM
bullredguy's Avatar
bullredguy
i sure as heck don't miss that type of weather i will take east Tennessee in the winter anytime as compared to what i grew up with in the upper midwest
Old Dec 19, 2008 | 05:22 PM
efx4's Avatar
efx4
When I ride on the beaches, I air down to about 20 lbs. I haven't aired down in the snow, but I understand it is a good idea to do so. 55 lbs. is just way too high and your tires will just want to sink into the snow instead of squatting and increasing to tire's contact area providind more bite. It is also a good idea to get a 12 volt tire air compressor to inflate your tires back up for the road, but a good quality one with enough power is a must. I keep one in my truck all the time. A hitch and tow strap is a good idea to carry with you is also a good idea, i've needed mine more than once, to help others as well as myself. Air down your tires, you wont believe the difference.
Old Dec 20, 2008 | 09:46 AM
WhëëlMå1's Avatar
WhëëlMå1
Sand and snow are VERY similar. As stated... you had way to much air in those tires. If you air them down, the truck will become damn near unstickable in snow. Its like adding snowshoes to your truck.
Old Dec 20, 2008 | 07:00 PM
RISUPERCREWMAN's Avatar
RISUPERCREWMAN
I have a 2007 SuperCrew 5.4, same BFG's All Terrain 285x70x17's! I have gone through several feet of snow!.........I do have a LS 3.73 rear axle......My truck is unstoppable in the snow!..........
