Sponsored by: Real Truck
vibration question
Old Dec 17, 2008 | 04:06 PM
mbergr1's Avatar
mbergr1
vibration question
Newbie here and I have a problem. I own a 2001, 5.4, F-250 with 180,000 miles on it. The truck vibrates only between 45-50 mph it seems like the rear end is bouncing between these speeds. Also the truck has a howling noise that starts at the same speed coming from the rear end. I guess im wondering if the carrier bearing, u joints or something from the drive line is bad and causing the noise and vibration?
Thanks for your help
Old Dec 17, 2008 | 06:40 PM
Fordfanatic4life's Avatar
Fordfanatic4life
yup thats were i'd start looking to..
also could be tires..
have u rotated em front to rear and see if teh noise/vibration is the same ???
Old Dec 17, 2008 | 07:59 PM
mbergr1's Avatar
mbergr1
The tires are 6 months old and just rotated them last week. My brakes need to be replaced pretty bad as well. Do you think that could cause vibration as well? How much of a job is it to do driveline work and what all should be replaced do you think?
Thank you very much for helping me
Old Dec 17, 2008 | 08:26 PM
big poppa's Avatar
big poppa
This is what i found one day while i was under my truck, a balancing weight on the first driveshaft coming out of the transfercase. I had a rrrrr sound and that was the problem. Used the one cent mod to fix. Put a penny were the weight was missing and wrapped some aluminum(metal) duct tape around the driveshaft and wala, noise gone. If the noise didn't go away i woulda paid to have it balanced.
