Weird Ideas for EGR
Old Dec 16, 2008 | 09:57 PM
drakul20us's Avatar
drakul20us
Weird Ideas for EGR
Hey guys, it's been a while.
I was mulling over hte EGR valve and cooler issue today and had an interesting idea. Not sure if it will work, so that's why I'm here.
First off, my EGR is currently unplugged, my cooler is fine, CEL is on.
Say you'd like to disable the EGR cooler, you'd by a freeze plug for the uppie or get a block off plate, whatever.
What would happen if you'd tap or weld in a bung in the cooler itself to draw in CNG or compressed air? So in theory the EGR cooler will act an extension of the air/CNG tank. It seems to me that the EGR valve will still be functional, the computer will detect flow, I'd think that you just insured yourself a carbon and CEL free engine. The only problem I can see with it is how much pressure can the cooler withstand?
I know the idea is goofy but et me know what you think nonetheless.
Old Dec 16, 2008 | 11:03 PM
cartmanea's Avatar
cartmanea
Well, you don't put a freeze plug in place of the EGR cooler, it has to continue to flow though only bypassed because the oil cooler is inline with it. CNG, I wouldn't bother with it.
Old Dec 17, 2008 | 07:26 AM
yz400f's Avatar
yz400f
You would just need a regualtor set at about 50psi (not a problem at all). There is not a true "flow" detection from what I read, it is a pressure Difference. Flow is infered. Any gas that is at a higher pressure than what is in the intake would work. Replacing the burned exhaust gas with a clean gas would not be detected. I do not however believe that this would give you the CNG benifit......................... unless you just plummed it to both the EGR inlet that you created and the intake. The higher pressure CNG will that the path of least resistance. Some would go through the egr valve when it opened and all the other times it would flow from the injection point.
I bet a tune is cheaper.
Old Dec 17, 2008 | 09:01 AM
rollerstud98's Avatar
rollerstud98
Between the up pipe and egr cooler to block it off is what he was meaning.
Old Dec 17, 2008 | 05:25 PM
06silvercrew's Avatar
06silvercrew
Ok so say in theroy that this worked, it would only take care of 50% of the EGR cooler problems. The other 50% is the cooler leaking and letting coolant get into the intake and ultimatley the combustion chambers. While its a neat theroy, I dont think the work involved would justify it. Fully delete it, get a tune and be done with it forever.
Old Dec 17, 2008 | 09:35 PM
drakul20us's Avatar
drakul20us
As I understand it, the reason for the cooler leakage is that the exhaust gas weakens the joints on it, thus allowing the coolant to enter the intake. The whole reason for this is not to gain any extra power or milage. It's just to ensure that the engine runs clean, without drawing too much attention to the fact that the cooler is missing or there are codes present.
Old Dec 18, 2008 | 10:24 AM
elee3's Avatar
elee3
My 04 doesn't get a CEL from unplugging the EGR. And it is an 04 build date, not a late 03.
